IR filters?
Discussion in 'Beyond the Basics' started by The_Caper, Nov 27, 2007.
  1. The_Caper
    The_Caper TPF Noob!
    Jul 5, 2007
    351
    Ontario, Canada
    Hi all:
    Can anyone tell me if it's possible to use an IR filter with the Canon EOS 350D? I have heard from other sources that the 350D does not work with IR filters to provide that cool white effect.
    Thanks all.
  2. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    you need to convert a camera to work with IR to get the right effect. :( There are photoshop filters actions and such that give somewhat similar effects...but obviously not the same.
  3. The_Caper
    The_Caper TPF Noob!
    Jul 5, 2007
    351
    Ontario, Canada
    How do I convert the camera to work with IR and has anyone out there done it?
    Thanks Sideburns.
  4. TCimages
    TCimages TPF Noob!
    Aug 18, 2007
    1,978
    4
    Northern Va
    you can use the IR filter on the 350D, but the kit lens has a hot spot if you go too wide. Also, it requires rather long exposures, making it very challenging. I suggest shooting RAW so you can adjust the WB to your taste.
  5. frXnz kafka
    frXnz kafka TPF Noob!
    Jul 9, 2007
    517
    Maine
    If you do a search on DeviantArt for "infrared 350d" you'll get quite a few results. A few of them mention their cameras are not modified.
  6. Josh66
    Oct 31, 2007
    14,604
    1,237
    Cedar Hill, Texas
    If you do a custom white balance of the grass the colors come out pretty good (black sky, white leaves).
  7. doenoe
    doenoe TPF Noob!
    Mar 4, 2005
    4,267
    23
    Hoorn, The Netherlands
    You most definetly can shoot IR with a 350. Just go to my site (signature) and see the Infrarood gallery. All of those were shoot with the 350D. Like mentioned, you can not use the kit-lens. You'll get a major hotspot in the middle of the pic. I use the Canon 50mm 1.8 MKII for IR, works like a charm. Best thing to do is shoot in RAW, way easier than making an Custom WB. This is because not every picture is the same, so you would have to make a new WB with almost every shot to get it right.
    And yes, longer exposures.....so a tripod is really needed.
  8. The_Caper
    The_Caper TPF Noob!
    Jul 5, 2007
    351
    Ontario, Canada
    Super fantastic! Thank you all for the input and thanks for the heads up doenoe. A IF filter and ND filter will be my next purchase.
    Take care.
