IS lens
Christie Photo
Kankakee, IL
Website
www.christiephoto.com
I'm shooting a job tomorrow and rented an IS lens. I've never used one before. Are there any considerations in using this lens. Do I leave the IS on the entire time regardless of my shutter speed. Will it place an additional load on the battery?
Thanks!
-Pete
Yep, IS eats the battery, but honestly it's negligible, unless you're doing loooong exposures. Read up on how many stops of IS you're getting from the lens; that is approximately how many stops slower you can have the shutter speed from your normal safe hand-holding speed.
On the old XTI it used battery a bit more. On the 1d mk III you cant tell a differance. If tripod shooting I usually turn it off (tripod on a moving ship) .
It helps freeze the scene but not a moving object.
Hope that helps Pete, honestly I never think about it eating the battery as its a non issue if you start the day with a fresh charge.
Cheers
The IS will not kick in until you half-press the shutter button. So I will assume it only use the battery while you are shooting.
Also, some IS lens has 2 IS modes. In my lens, mode 1 is good for any hand held shots, mode 2 is good for panning type shots. (motion compensation for horizontal movement is disabled)
Nice. Where did you rent from and how much. I have always bee curious about how the renting process works. Do they charge from the day they send it or the day you receive it?
I got it from Calumet in Chicago. It's a Canon 24-105 f4L. The rate is $30/day or $90/week. This is my first lens rental. It was fairly easy for me. I've had a 30 account with them for over 20 years, so I didn't have to come up with the $1000 deposit. And yes... they will bill me from thier door to their door.
-Pete
Good luck with it Pete. It's pretty straight forward, you shouldn't need to adjust your shooting style any...except that you can expect to be able to gain a few stops before you have to worry about camera shake. So where you might limit yourself to 1/60, you could shoot at 1/15 for example.
Do keep in mind that it only prevents blur from camera shake. If your subjects are moving, they will still be as blurry at 1/15 as they would be without IS.
And as mentioned, turn it off if you are on a tripod etc.
