iso and focus
tbrownarcher
Council Bluffs, Iowa
Here is a picture that i took at about 10:00 pm. I used an sp 550 uz Olympus camera.
the settings were.
shooting mode.... manual
Focal Length....... 8.6mm I do now know how this is set unless it's the zoom
Shutter ............. 2.sec
f.NO.................. F4.0
exposure............. 0.0 EV
flash................... OFF
Color Space.......... sRGB Where do you set that ?
ISO Sensitivity ..... 5000
Macro.................. Off
http://i220.photobucket.com/albums/dd254/tbrownarcher/P9020012_01.jpg
My question is one of quality. I realize that the 5000 iso I used is really high. I'm just trying to get a fix on what I'm doing wrong. I have experimented with smaller ISO and aperture settings but the quality seems to be a bit lacking no matter what I do ... Is taking a night picture like that going to be just like this or can I get better ...
Thanks,
Tbrownarcher (nate)
I'm gonna send this first and see if i can upload image later after i read the instructions since i don't see an option to upood here
You have to upload them to a photo hosting site and link to them.
Yep! I'm trying ! I got them up there I jsut haven't had a chance to edit and put a link up should be there in a few minutes
Thanks,
tbrownarcher (nate)
In my opinion an iso speed of 5000 is almost completely useless. Use a much lower iso and a much slower shutter speed. Those two things plus a tripod will equal much better quality night shots. An example could be 100 iso and around 30 seconds for your shutter speed.
Higher ISO = Higher Noise
What was your White Balance set to?
have a good one
3Eo
Lower your iso, 100-400 (I prefer lowest), Smaller aperture to get longer detail, Wider aperture to get focused detail, USE TRIPOD (a must), cable release or remote to avoid camera shake... then, try different speed, you could get many result from different speed (15sec, 30sec, 60sec, etc)
For a night picture ISO100 is a must with digital cameras. Noise is induced with longer shutters, but it is induced even more if you amplify the signal from the sensor (increase the ISO). The lack of sharpness in those images looks like the result of very aggressive noise reduction needed to make the image viewable.
I read in "Practical Photography" a few months back that one should at all times try to use the lowest possible ISO setting. So if the lowest ISO setting for your camera is 200 you should use this as often as possible. This is to reduse noise. (I remember my first SLR (35mm) when I used ISO 100 or 200 film the photos where of great technical quality, but when I used 800 or higher the photos becomes grainy.)
three eyed otter:
there is a menu for white balance but it's just a bunch of icons i don't understand. It was set on Auto wb when these pictures were taken
I can't find my book right now but i remember seeing something that said to take a picture of a white sheet of paper being mindful of shadows. I wonder isn't that going to also be dependant on the type of light and the intensity of it ?
How do i set it ?
Thanks,
tbrownarcher (nate)
Garbz:
Here again I have lost the book tonight. (instruction book) I can't seem to get more than a few seconds shutter speed. I think 4 seconds is it. I do remember that I can keep the shutter open for several minutes but I don't know how and I can't find the book nor when I did have the book could i understand what it was telling me.
It seems the camera is more automatic than just in the Auto setting. I'm having trouble taking control of it even in the p s a and m settings. It has a mind of it's own and mine seems to be subject to it rather than the other way around .
thanks,
tbrownarcher (nate)
