JPEG, RAW, or BOTH
Discussion in 'Photography Beginners' Forum' started by sdgmusic, Jun 21, 2007.
  1. sdgmusic
    sdgmusic TPF Noob!
    Mar 11, 2007
    93
    Mississauga, Ontario, Canada
    I have a DSLR and have had it for a while. I need to know, what are the advantages of shooting RAW. I haven't yet because I can't justify creating picture files that are 15MB each or more. If there are amazing benefits I will try it. Can you help?
  2. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    This is an older article, but it should give you a good start to the RAW vs Jpeg issue.
    http://www.ronbigelow.com/articles/raw/raw.htm
    I think that for most people, the drawbacks of using RAW are the file size and the workflow. Well, memory cards are cheap and upgrading your computer if it's too old and slow, is an inevitably.
    As for workflow, it gets easier with practice and the right software. I shoot RAW almost exclusively since I started using Raw Shooter Essentials. I plan to get Adobe Lightroom someday.
    As for shooting both...I don't see a reason to do that. It just takes up even more space. It only takes a few seconds to get a JPEG file from a RAW files...so why record a JPEG in the camera?
  3. Johnboy2978
    Johnboy2978 No longer a newbie, moving up!
    Oct 21, 2004
    1,797
    30
    Southwest Virginia
    I've been shooting RAW for a while now, maybe a year. I was hesitant to do so at first b/c of the extra steps involved in opening them and viewing them. I started doing paid jobs though, and decided it was time to do so. At first, it's a bit of a hassle developing a good workflow, I'll admit that. The other side is that you can have complete control over the development. It is also a lossless format and it will not be compressed. I have personally had several success stories in which I had images that were "saved" by shooting RAW. In one situation I had an image that was completely underexposed (like -4) due to the off camera flash not having time to recycle. I was able to adjust the WB and completely recover the image. A jpg of this would've been useless and deleted. It's worth playing with to see what you can do with it.
  4. GwagDesigns
    GwagDesigns TPF Noob!
    Jun 11, 2007
    173
    9
    Washington
    There is also an automated action within the RAW dialog, which will enable you to convert all selected files to jpegs, and save them where you choose. Id just shoot in RAW, and convert them later.
  5. tr0gd0o0r
    tr0gd0o0r TPF Noob!
    Jun 29, 2003
    942
    4
    Shreveport, Louisiana
    The reason I shoot exclusively in jpg is the time in which it takes to post-process. While it may not take long to convert one raw file into jpg, doing it to the several hundred photos I shot while on assignment would end up taking quite a while. However, most of my shooting is photojournalism, so speed is somewhat more important than most other applications.
    Along the same lines, I was showing one of my newspaper friends my mark II (which is capable of writing both formats to two different cards.) And he commented that the feature might make him start shooting raw because he could look at the jpgs, and then choose which files to edit from raw.
  6. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    Yes, if speed is a big factor, then JPEG may be a better option for you...but even with several hundred photos...you can process them in batch in very little time.
    Another thing I just thought of...RAW images fill a camera's buffer faster and take longer to clear. So if you are a machine gun like sports shooter...you may want to shoot JPEG rather than RAW.
  7. darich
    darich No longer a newbie, moving up!
    Jan 22, 2005
    1,230
    Near Lanark, Scotland
    Exactly the reason i shoot both - RAW for editing/printing and jpeg means that windows can give me a thumbnail of each one and i can choose which ones to edit/delete.
  8. Alex_B
    Aug 30, 2006
    14,491
    206
    Europe 67.51°N
    well, batch conversion does not take long ... just as good as shooting jpeg directly .. but with the advantage you can go back to selected images with complicated light or white balance .. and give them some extra treatment with some more effort in the conversion to jpeg
  9. eravedesigns
    eravedesigns TPF Noob!
    Feb 19, 2006
    624
    I just shot in RAW yesterday which is pretty rare of me to do and I am so happy i did. RAW allowed me to fix the under exposed images that I shot without losing quality and I was also able to adjust other settings without losing quality which was nice
  10. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    Thanks for posting that link. It explains to me why I would get a halo effect (jpeg sharpening) in some photos when post processing. ie; the reason I use raw.
  11. RVsForFun
    RVsForFun TPF Noob!
    Mar 20, 2007
    184
    ...and you have the software for RAW processing, shoot RAW. You can go back later and change the conversion parms to re-do your resulting JPEG at any time. Personally, I shoot over 1,000 images a wedding so I shoot JPEG in-camera for speed and space reasons. Since I edit each and every image, batch conversion of either RAW or JPEG isn't feasible.
  12. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Seriously I have the cheapest modern computer there is. Batch converting 100 images right off my very very cheap and slow memory card takes at most 10-15 minutes. If you do this stuff at home, drink a coffee and come back. If you're out on assignment you may really want to consider taking more memory cards, or shooting jpeg.
