adamhiram
- Joined
- Feb 6, 2015
- Messages
- 858
- Reaction score
- 576
- Can others edit my Photos
- Photos OK to edit
I have used this large format "scanning" setup sporadically for a few years now, based on the "standard copy setup" in chapter 4 of Light: Science and Magic. The copy surface is a piece of plywood to keep it flat, the document to be scanned, and a piece of plate glass over it to press it flat. Lighting is from a pair of large double-diffused square softboxes fired at equal power and metered to match the lens's aperture (usually f/5.6 or f/8).
This has worked well for me, except I've always scanned old documents I wanted to digitize or the occasional photo print, where I didn't notice anything strange. Then I recently went to scan a darker photo and realized a big problem with this setup - even though the lights are at 45 degree angles, the camera (and my arm) are reflected in the glass. There must be a way around this, but I have yet to figure it out.
Hopefully someone here can provide some suggestions on how to eliminate this reflection.
Some thoughts I had:
Here is the setup I use:
20200525-DSC_9601a by adamhiram, on Flickr
Here are some sample shots with a random inspection sticker from my tripod on some standard printer paper and on a piece of black construction paper. For the last shot, please ignore the dust I neglected to clean the dust off of the glass.
This is what it looks like when I scan a brighter document - no observable issues:
20200525-DSC_9588a by adamhiram, on Flickr
Here is where the reflections become noticeable:
20200525-DSC_9589a by adamhiram, on Flickr
- Change my setup - perhaps flag the light on either side of the camera, or raise the camera above the height of the softboxes to prevent it from being illuminated. Here, I run into issues with extending the tripod arm horizontally too far and have stability issues that would likely require additional gear.
- Should I be using a different type of glass, such as something with an anti-reflective coating? Right now I'm using a cheap piece of plate glass from the hardware store.
- Perhaps a circular polarizer on the lens would be an easy fix? I've been looking for an excuse to pick one up, so this could be an option as well.
