Lens question
Easy_Target
Okay, so I'm using an FM10 and on the Nikon site, it says that the FM10 can use the following lens types: Usable Lenses: All Nikkor AF-D, AI-P, AF-I, AI-S and AF-S lenses.
The B&H site has a lens that I'm looking to get (80-200mm) as a D-AF autofocus lens.
I don't think that there's a difference in the transposition of the D/AF, but I could be wrong. Can anyone clear this up for me?
http://www.bhphotovideo.com/c/produ...n_1977_80_200mm_f_4_5_5_6_D_AF_Autofocus.html
It's also an autofocus lens, but the FM10 doesn't have CPU contacts for the autofocus, it should still work fine in manual focus though, right?
I would expect that it will work perfectly with manual focus but I can't speak from experience. If you're in the states, why not call B&H?
It will work fine, but it's an FM, so you'll have no AF.
I used my 80-200 AF-D on my FE alot and it worked perfect every time.
Basically, if it's an F-mount lens that's AI'd You can use anything with an aperture ring on it.
