Does anyone know what the first thread is called (to avoid repeat questions)? I am having trouble finding it
Hi, Village. Thanks for doing this. I have an Alienbees b800 with a shoot through umbrella and I'm ready to expand a little. I'm looking at another b800, but with a softbox. Do you think this is a good route? Eventually, I'd like to have a few more, but do you think this would be good for a two light setup, or is my money better spent elsewhere?
Thanks,
Ryan
I'm usually shooting around the house if I'm using the external flashes... Portraits of the daughters....
OK, here's one, when shooting a group of 20 people, would I be better shooting through an umbrella or bouncing off the umbrella?
Equipment is limited, I have one monolight and two speedlights.
I've never shot a group that big but I'd shoot through. Make sure the umbrella is large enough or close enough to the light so you're not getting spill from it.
Personally what I would try is setting up the monolight in the middle of the group and pull it back to get the widest coverage possible and then place the strobes on the side to help boost the exposure where you'll be getting fall off from the main light.
A light meter would help a lot, so you could pop off the flashes and test the exposure to get it as even as possible.
Opticals can be finnicky. What conditions are you generally shooting in?
#1 - Will using a speedlight on my D60 allow me to utilize a higher sync speed than the pop-up flash's 1/200?
#2 - Theoretical... I want to photograph a subject and flank it on both sides with speedlights, or some sort of flash. How do I go about doing this... A) Physical setup? Two speedlights on two tripods? B) How do I remotely fire them? I assume something attaches to the hotshoe of my camera for this. I'm looking for the specific items I need. I'd like the ability to control each flash independently from the camera if possible.
#3 - What's a monolight and how does it differ from a speedlight? What are it's common uses?
I'm a Canon shooter and don't know much about Nikon flash sync...a Nikon shooter will have to answer this.#1 - Will using a speedlight on my D60 allow me to utilize a higher sync speed than the pop-up flash's 1/200?
Two Speedlites mounted on two light stands (with swivel adapters for angle control).#2 - Theoretical... I want to photograph a subject and flank it on both sides with speedlights, or some sort of flash. How do I go about doing this... A) Physical setup? Two speedlights on two tripods?
Do some research into the Nikon Creative Lighting System (CLS). It may be able to do what you need...it may not.B) How do I remotely fire them? I assume something attaches to the hotshoe of my camera for this. I'm looking for the specific items I need. I'd like the ability to control each flash independently from the camera if possible.
Wikipedia: Monolight - Basically, it's a self-contained studio strobe.#3 - What's a monolight and how does it differ from a speedlight? What are it's common uses?
Here's another one for you, VI, when shooting in AUTO (I know, I know..) and using my external flash, sometimes, not only does the flash not benefit the situation, but it will make the picture darker! Is this just my camera reacting to the unexpected light that it didn't see when it metered?
I'm a Canon shooter and don't know much about Nikon flash sync...a Nikon shooter will have to answer this.Two Speedlites mounted on two light stands.
I've seen this happen if the flash is set to TTL and there is a highly reflective object in the shot...the flash bounce-back tricks the TTL system into thinking enough light has been applied and it shuts down the flash too early. Usually happens when you shoot a mirrored surface. If you have to get the shot you gotta go manual.Here's another one for you, VI, when shooting in AUTO (I know, I know..) and using my external flash, sometimes, not only does the flash not benefit the situation, but it will make the picture darker! Is this just my camera reacting to the unexpected light that it didn't see when it metered?
I'm not sure I know the answer to this. Are you shooting in TTL? Where are you shooting?
