LIGHTROOM QUESTION
Discussion in 'Graphics Programs and Photo Gallery' started by hombredelmar, Jul 25, 2014.
  1. hombredelmar
    hombredelmar No longer a newbie, moving up!
    Apr 3, 2014
    358
    26
    NY
    Can someone explain the situation?
    1. I open lightroom then I import a folder I work with in lightroom. I save a couple of versions of the same picture and I can see them each time I save it, however I cannot see it in the original folder on my computer. What do I do?
    1. Lightroom creates lots of unneeded folders, I guess the folders I import to lightroom. It does not help but creates confusion. What do I do?
    Thank you for in advance for your help !
  2. lambertpix
    lambertpix No longer a newbie, moving up!
    Sep 27, 2013
    938
    368
    Columbus, OH
    LR has a ton of file handling options it can use during imports. It sounds like you might need to just sit down and figure out what your typical workflow is going to be. I know when I started, I was working way too hard with LR -- I copied files off my memory cards manually, then used LR to point to those folders. When I finally figured out I could let LR just copy the files off the card and into a destination directory, it saved me a ton of time.
    The multiple versions, btw, sound like maybe you created the copies in LR. If that's the case, you're experiencing the non-destructive editing in LR. Since it's storing all of its edits as "instructions" rather than actual image changes, creating a copy is also an instruction, which means that your original file is untouched and uncopied. The copy is virtual.
  3. hombredelmar
    Apr 3, 2014
    358
    26
    NY
    Thank you for your prompt response, I definitely need to seat and figure this out.
    Thanks once again
  4. sscarmack
    sscarmack Been spending a lot of time on here!
    Jul 14, 2009
    2,360
    946
    Sharpsville,PA
    Check out youtube, ton of helpful videos.
  5. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    12,467
    3,047
    SE Michigan
    You only see the "final" picture when you EXPORT the image or work with it in Lightroom. Then Lightroom takes the original file, all the respective changes (crop, exposure, etc) and exports it to a JPEG or other file for you. A RAW/NEF file provides more ability of changes than a JPEG when imported.
    Info on how Lightroom uses a Catalog (where it stores all the changes to the image) --> Lightroom Catalogs Explained
    Other info --> Lightroom catalog FAQ
    More --> Where are my Lightroom Files? - Digital Photography School
    You should learn how to use Collections
    info --> Adobe Photoshop Lightroom 4 * Photo collections
    more collection info --> How I use Lightroom?s Collections | Scott Kelby's Photoshop Insider
  6. BenjaminJ
    BenjaminJ TPF Noob!
    Aug 27, 2013
    48
    11
    Michigan
    Lightroom doesnt save actuall copies of photo edits, it just saves the information of the edits and puts that info into a different folder. In other words, you can take a certain photo, make copies of it in lightroom and do different edits on them. In your photo folder, you will still have the single photo and it will appear unedited unless you view it in lightroom. In order to make the edits permanent you have to save as (called export in lr) a jpeg file. Those will appear in the folder of the original picture. This is also why it is important to use the weekly back up function of lightroom and have it saved to another drive incase something goes wrong on your computer. Without the backup, if something happens to your computer, all your edits will be lost on any photo that you didn't save as a jpeg (which can end up taking up a lot of space).
  7. PWhite214
    PWhite214 No longer a newbie, moving up!
    Aug 6, 2011
    208
    53
    Houston, Texas USA
  8. KmH
    Apr 9, 2009
    39,373
    5,310
    Iowa
    There is a lot to consider when it comes yo managing your digital image assets.
    You can spend hours gleaning disjointed bits and pieces from some number of YouTube videos you may or may not discover, or you can get all the info you need in one place:
    The DAM Book: Digital Asset Management for Photographers
  9. hombredelmar
    Apr 3, 2014
    358
    26
    NY
    Thank you for the link!!!
  10. hombredelmar
    Apr 3, 2014
    358
    26
    NY
    Thank you for the info, to tell you the truth i am kind of lazy to read the book and to spend money on it. However that you for your time, i might deside to buy it one day.
  11. hombredelmar
    Apr 3, 2014
    358
    26
    NY
    thank you, that was very informative
  12. hombredelmar
    Apr 3, 2014
    358
    26
    NY
    the best idea, i thought about that!!!
lightroom as digital asset manager 2014
