Liquid Light
Discussion in 'Alternative Techniques & Photo Gallery' started by itakepictures, Dec 7, 2007.
  1. itakepictures
    itakepictures TPF Noob!
    Nov 16, 2007
    Hi my name is Adam I am in my third year as a photo major at school. I may have bit off a little more then I could chew with my final photo project. I have recently started playing with liquid light and thought it would be a fun project to do for a final is to put images of skateboarders on broken skateboards. The first one came out fine nice over all tonality of the print. How ever I ran into a bit of a problem. Some of my negatives lack contrast which is making the image very gray and flat. I have no blacks or whites. I tried scanning the negatives adding contrast in photoshop and contact printing them. I also tried making a negative to enlarge in photoshop the only problem is the ink-jet transparencies have these little bumps I suppose to grab the ink and it is causing dark dots on my prints almost like it is pixelated.
    My question is how can I make the liquid light more contrasty? My teacher suggested developing in straight dektol. Another teacher said that may not work.
    A little background these are skateboards broken in half. Coated with some white matte spray paint and a coat of clear polyurethane on top.
    Any help would be great my crit is TUESDAY!
    Thanks,
    Adam
  2. Alpha
    Alpha Troll Extraordinaire
    Mar 15, 2005
    5,454
    41
    San Francisco
    You could:
    a) Lith print the boards, or b) Make a high contrast negative from the original, then print that.
  3. itakepictures
    Nov 16, 2007
    I tried making my own high contrast negative and it doesn't work because of the grain on the transparencies for the ink-jet printer.
  4. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    I mean make a real high-contrast negative. Make normal print of the shot (if the negs are soft, perhaps a grade 3), then contact print that onto LF film. An orthochromatic copy film would be good for this, as they tend to be slow and you can work with it under safelight. I'd recommend something like the Arista APHS half-tone. You could also try Adox/Efke ORT25/PL25. They're all available from Freestyle Photographic, and aren't very expensive. 25 sheets of the 8x10 APHS will only set you back $18.
    Edit: I should add, in case you didn't know, that it has to be a red safelight. An amber one will fog the film.
  5. KMac
    KMac TPF Noob!
    Oct 24, 2005
    27
    Ontario
  6. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    you're working with negatives, which I would guess you've been using enlargers and making real B&W prints.
    Why don't you use contrast filters?
  7. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    A grade 5 perhaps, if available.
  8. itakepictures
    Nov 16, 2007
    thanks I tried it and it just beaded off the skateboards. You can't use the contrast filters with liquid light.
  9. Alpha
    Mar 15, 2005
    5,454
    41
    San Francisco
    Lith print it.
