Long Exposure - What settings?
Discussion in 'Photography Beginners' Forum' started by crowl31, Aug 22, 2008.
  1. crowl31
    crowl31 TPF Noob!
    Oct 26, 2007
    93
    This may be a dumb question but if I want to take a long exposure of say a water fall what should i set my camera to?
  2. dEARlEADER
    dEARlEADER TPF Noob!
    Apr 9, 2008
    1,312
    Canada
    the proper exposure.....
    for water fall shots you need to
    -shoot in manual
    -use a neutral density filter and/or a polarizer to limit the amount of incoming light
    -use a smaller aperture like f11 or higher
    -use a tripod
    -use you cameras light meter as a starting point for the correct exposure
  3. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    First of all, you'll need to use a neutral density filter, because no lens can close it's aperture enough to compensate for the amount of light you'll be letting in with a long shutter time.
    Start by using your camera to shutter priority mode and setting the shutter for 3-5 seconds and then try bracketing from there.
    And, of course, you'll need to use a tripod.
