Manual setting
Discussion in 'Photography Beginners' Forum' started by DxAxN, Sep 17, 2010.
  1. DxAxN
    DxAxN TPF Noob!
    Aug 28, 2010
    218
    Lake Charles, LA
    Well I finally took it out of Auto and into manual... and things just went down hill from there. Having to adjust your settings every shot was a real challenge and the fact that it was partly cloudy didnt help. Seemed every time I was ready to take a shot the sun would come out and I would need to readjust. I thought I had taken some good shots but when I looked at them when I got home they were far less than what I expected. Seems that anything with a light color was overexposed. Of course I really didnt have a clue on where my starting point should be...Basically I turned on the camera put it in M and followed the metering indicator and made my adjustments off of that. Oh well...at least I had the day off.
  2. peanut170
    peanut170 TPF Noob!
    Jun 20, 2010
    291
    Vancouver, Washington
    If you've only shot in auto, maybe just try S, or A, priority to start. That way you can learn a little at atime, and it might not be so overwhelming. Just athought, but hey guess the best way to learn is to just do it and keep practicing. Either way good luck, I still struggle all the time so i feel ya.
  3. icassell
    icassell No longer a newbie, moving up!
    Jun 7, 2008
    9,900
    15
    Arizona
    I hope you didn't think you'd figure this all out on your day off. Those of us from the film-era can remember wasting many many rolls of film as we learned this stuff. Don't give up. It may not be easy, but when you're done you'll have a much better understanding of the exposure triangle. Have fun with the challenge.
  4. Negative ISO
    Negative ISO TPF Noob!
    Aug 25, 2010
    99
    Alaska
    It took me some time getting acquainted with the different light metering modes on my camera when I started shooting in manual. I have more to learn yet, but have started to get a feel for when to use evaluative vs partial weighted metering. (I haven't tried center-weighted average yet). I'm happy enough that I'm getting it right pretty often now. (probably just jinxed myself now!)
    I'm not sure this is the _best_ approach, but when there is a brighter area I often meter off that and sort of guess how much to vary my exposure. I usually try to take a few shots at different exposure settings, especially when I'm feeling unsure.
    One thing you might also consider is setting your camera to shoot in bracketed mode at 2/3 - 1 full stop increments. I did this for a short while as well.
    Overall I seem to find that I now error on the side of under-exposing my shots, but they usually still come out about right. I still over-expose them more often than under-expose.
  5. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    40,488
    15,216
    USA
    This scenario is one where most experienced photographers understand the value of automatic exposure metering. Peek-a-boo sunlight.
  6. AdrianC
    AdrianC TPF Noob!
    Aug 1, 2010
    155
    Edmonton
    Most people just shoot in aperture priority.
    Manual is usually used if you want to achieve a certain effect, or if your camera's meter is getting tricked.
  7. Blake.Oney
    Blake.Oney TPF Noob!
    Aug 26, 2010
    560
    Olive Hill, Ky
    This is what I do. No shooting in Manual just to say I do. Aperture priority is faster for me and most of the time it just works. If I don't like the result or I need something specific I'll go into manual.
  8. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    Welcome to the wonderful world of photography. At least you're playing w/ digital and spending about $0.10 cents per click (shutter life) and not a $1 per frame, like number of us did during film days.
    Shooting manual has its positives and negatives. But it takes practice and time to get used to. It also takes experience reading the scene.
    As many mentioned and I'll second it, shoot in PSA modes. CAREFULLY look over your shots and see what camera was doing and WHY it did what it did. Play with different metering modes - based on the scene your exposure might vary. Play w/ auto modes at night/dark and see what camera is doing...
    Shooting in M has its privileges but to get there you really should know and understand more about exposure and how different factors influence it. (iso 400 f8 1/125 = iso 100 f4 1/125 = iso 100 f8 1/30) All will give you the same exposure but looks will be different.
    if you want to PM and discuss more, go ahead.
    Good Luck
  9. sobolik
    sobolik TPF Noob!
    Jan 1, 2006
    675
    The only challenge to shooting in manual is speed of execution before something changes. You have a bazillion dollars and hours worth of research/technology in your hand that tells you what settings to use in manual.
    Take a reading in auto and note the shutter speed and aperture.
    Switch to manual so that you can deliberately do what you want. Lets say to want to do shutter speed tricks. For every click (stop) you vary on the shutter speed from the auto recommendation you must make a corresponding number of clicks (stops) on the aperture. The net result is the same overall exposure in terms of EV as would have been made following the auto suggestion. If you want to do aperture tricks then the shutter speed gets the follow along clicks.
  10. IgsEMT
    Jul 27, 2009
    2,694
    49
    NYC
    Depends how the camera setup. Mine are set in 1/3 of a stop.
  11. DxAxN
    DxAxN TPF Noob!
    Aug 28, 2010
    218
    Lake Charles, LA
    Thanks for the input...it wasnt until I was at work this morning when I thought to myself...why didnt I just use the S or A modes to start out. So I am gonna go that route next time.
    Nah I didnt think I was gonna learn it all in one day...I just wanted to go out and shoot and try and progress...but I can say if I had a big ego I would have been humbled by the "M"
    I tried a few differnet things while I was out yesterday...B/W...slow shutter speed to get a blury effect
  12. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,965
    14
    Durham, UK
    I shoot predominantly in aperture priority, I use manual after assessing a scene if it requires it, or use exposure compensation, camera manufacturers spent millions on this, so if one mode can make life easier, use that mode, you'll not get a mutley badge for shooting full manual, what you will get till you master it is a whole lot of missed opportunities and shots. H
