- Joined
- Mar 8, 2011
- Messages
- 25,324
- Reaction score
- 9,106
- Location
- Iowa
- Can others edit my Photos
- Photos NOT OK to edit
Format will not be as apparent as other factors such as lens, lighting, and post. I have taken shots with small medium and large format cameras and often cannot remember which was used where from the image.
My thought with switching format was to eliminate some of the distortion you get with wide angles. The not that there will be a dramatic difference, but there would be enough to make it worth a try.
You will have far less optical distortion with large format since there's no flange-focal length issues needed to overcome with optical designs. Medium format still suffers from this since there's still usually a FFL distance involved. But unless you have access to MF digital gear, you're shooting film then scanning.
If you're using 17mm as a basis for a full-frame DSLR, you'll be looking at somewhere around 30-35mm for MF and 50-60mm for 4x5.
4x5 w/ 65mm:
All perspective correction done in-cam. No distortion.
