MF - 35mm "Crop Factor"
Discussion in 'Beyond the Basics' started by Johno, Nov 8, 2006.
  1. Johno
    Johno TPF Noob!
    May 26, 2006
    316
    British Columbia
    I'm currently working on a proposal for our Aerial photography company to convert from Medium format film, to a full frame DSLR. It's not the resolution I am concerned about in this thread so lets not get into the MF>DIGITAL discussion again :) What I need to know is the Equivelent focal length conversion factor ("crop" factor) for MF to 35mm. Currently we use a Hasselblad MK70, with a Zeiss 100mm lens, vertically mounted in the bottom of our Cessna, with a CC television camera mounted next to it to see the target through an LCD monitor in the dash. It costs us about $4.20 per exposure (Film, Processing, Prints and scanned) The prints end up in several large storage units in the basement and the scans are sent to clients. A digital camera would cut the cost per exposure to $0.03-$0.06 and the processing time would be cut down from a week (They don't develope 80 exposure 120 film here, have to mail it out) to a couple fo minutes.... The only thing the boss is concerned with is the cameras field of view, If the field of view is smaller, We have to fly higher to cover the same area and fuel is more expensive than film! The distortion that the equivelent 35mm lens would produce is not a concern, we have corrective software for that. Any help would be greatly appreciated!
  2. fmw
    fmw No longer a newbie, moving up!
    Sep 30, 2006
    2,988
    245
    A 100mm lens on a 6X6 medium format camera is just a touch longer than normal. The equivalent in 35mm (or full frame DSLR) would be 60mm. A 50 would be close enough and allow you to fly lower.
120 to 35mm crop factor
conversion factor lens medium format 35 mm
crop factor for 120mm medium format camera
crop factor medium format to 35mm lens conversion
medium format crop factor
medium format lens on 35mm crop factor
medium format to 35mm crop
medium format to 35mm crop factor
medium format to 35mm equivalent
mf crop factor
