Better ?First, you should probably label this thread NSFW just to warn people.
Second, lovely model and nice photo. I'd probably go B&W on this...it would emphasize the lines much more (which are lovely). Also, I'd lighten the hair on her right side a bit (it has lost some dynamic range).
Thanks for sharing.
Some jpeg artifacts came out of the woodwork ... but this wouldn't be a problem with the original. From my color correction (below):
Channel Mixer - 107/23/30
My color version, too magenta?
When working on b/w, I recommend not converting to b/w to later adjust primary contrast. Allow the color data determine contrast, then fine tune tonality after if needed. Keep the color version on the bottom of your layer stack and use something like channel mixer to do the conversion close to the top. If you need to output to a single-channel, convert to greyscale at the very end only if needed, such as going to monochrome offset.
Much better. Merci beaucoup.Better ?First, you should probably label this thread NSFW just to warn people.
Thanks for sharing.
