Need a 70-200mm lens! [nikon]HELP!
Pure
So I'm buying a D90, but I can't afford a 70-200mm f/2.8
What can I get that won't cost more than 1000 but still has a similar range?
f/3.5 is fine becuase it will all be high light, lower ISO so speed isn't super necessary.
How about:
Tamron 70-200 f2.8 Di LD IF for around $700
Sigma 70-200 f2.8 II EX DG $800
A Canon 40D and 70-200 f/2.8?
Heh...That's what sucks about Nikon's 70-200 line. They have one.
Look at the Nikon 80-200 f/2.8. I hear that's a good piece of glass and is only about $1000, iirc.
The sigma is a tack sharp lens, I would honestly go that route.
The Tamron tests out better than the Sigma particularly as you get closer to the 200mm end.
skieur
I have the Nikon 80-200 f/2.8D and it's razor sharp, and built to last. It's dropped 6 feet onto asphalt and it still works and is just as sharp as the day I bought it, even when the cap and lens hood shattered on impact.
Since $1920 is totally reasonable price for both, and reading reviews about the 80-200 i'm going to go with that.
Where else can I get the D90 since BH is sold out?
skieur
I've shot with both, and felt the sigma was th sharper of the two. May be the particular samples I had, but that's my opinion.
Also, I need a good, and strong monopod for under $40
I was considering the 70-200mm for when I buy new lens(January, haha).
I wasn't sure yet though. I also looked at the 80-200mm. Ive read the 70-200mm is bettery, but not by that much. I got a few months, so we'll see.
How are Tamron and Sigma lenses compared to Nikon? I wouldn't mind paying more $ if Nikon is better. I'm also not sure if I want a f/2.8. It'll be used outside, who knows.
Well the 70-200 is better, but it costs almost double than the 80-200.
The 70-200 is $1700 and the 80-200 is $950ish.
The main difference is the lack of VR and a smaller focal range, and like 1 less ED element.
The 70-200mm for sure is worth the money, its rated as a pro lens.
If you can afford it, Tenlienti, I would say get the 70-200 VR. If you get it used, then it won't be that much more than the 80-200, and the addition of VR means you can use the lens in the darkest of nights without a tripod (well, maybe that's a little extreme, but VR can make the difference).
To Pure: I would say that if you need a monopod, don't skimp out on it. If you're going to be spending $2,000 on kit, it's well worth buying a $100-150 monopod or tripod. It's like buying an Aston Martin, but only getting it a $10 DIY car alarm kit for it.
