IgsEMT
- Joined
- Jul 27, 2009
- Messages
- 2,694
- Reaction score
- 50
- Location
- NYC
- Website
- www.pictureperfectny.com
- Can others edit my Photos
- Photos NOT OK to edit
Need a little help with 3 mentioned above - here's what happened.
Last night I was shooting a job with D300s being the primary, D90 being the back up. D300s was mounted on a bracket with Sb29 connecting the camera and sb800 flash. Quantum radio was hanging on the flash connected INTO the camera via pc cord.
I finished the portraits (SB800 was off) everything was fine, went portable... About an hour into reception (during speeches) flash stopped firing - TO CORRECT it:
*****batteries were fine,
*****took it off the ttl cord and connected directly to the camera - doesn't work
*****flash indicator ON CAMERA not lighting up.
I changed the flash unit and everything SEEMED to be in order. About 5mins later AGAIN it stopped working.
I switched the bodies with "original' SB800 and it worked for a little bit so I switched to 2nd SB800 and all seemed to be working (D90 with backup SB800 with quantum plugged into flash via pc).
During brake I removed the battery from D300s and placed it back in flash worked:thumbup: but then stopped working :thumbdown:
In "flash control ON CAMERA" I changed from Commander to TTL again it worked :thumbup: for a little while :thumbdown:.
SO back to D90 and Backup flash unit...
First time in years have this happened to me (kind of proves a point never go on assignmenet w/o a back up gear).
I got home, loaded the job on the computer and surprisingly it came out great, except those times when light wasn't firing.
Placed the camera-flash combo and just began shooting and shooting and shooting - NO FAILURE. Then switched combination of flash and camera - NO Problem :thumbup:
Has anyone had this sort of weird thing happened to them and/or know WTF happened?!
thank G-d for backup
thanks
thanks
