Nikon D800 + Nikon SB-28 speed light
Knik
Wasilla, Alaska
Hi All,
I recently purchased the Nikon D800. Is there any reason that my Nikon SB-28 SpeedLight cannot be used or should not be used (e.g. harm to the camera) with the new D800? If it can be used, should I expect it to completely function as it would using the conventional film camera?
Thanks
Kink
It should work totally fine, but I think those are "D-TTL" instead of the new "i-TTL" system so TTL won't work. So as Mach0 says, it'll only function as a manual flash. The slave modes should still work fine as well, and it definitely won't do any damage to your camera.
I almost bought a pair of SB-28's when I get my D800, but I went with YN-560 II's since I figured they'd be all manual anyway. I don't really see that as a disadvantage, as 99% of the time I use flashes on manual anyway as I'm setting up lighting or bouncing off of a ceiling during events which wouldn't be a TTL function anyway. That's why I went with a couple of cheap flashes instead of a single SB-900 as I had originally planned.
Since you already have an SB-28, for sure put it to use. It'll perform perfectly normal on your D800.
Sb28dx has a slave mode. The regular 28 doesn't.
