Nikon DX lens vs. VR lens
Discussion in 'Photography Equipment & Products' started by snowalker, Aug 21, 2008.
  1. snowalker
    snowalker TPF Noob!
    Nov 4, 2007
    62
    toronto, canada
    Hi everyone,
    I have to buy a Nikon D60 and sell my Nikon 70s which is working with 18-55mm DX.
    The question is, is there a big difference between DX and VR lens?
    In this case its worth to sell the DX lens or is good to keep it for the new D60?
    VR lens is coming regularly with D60.
    I'm gonna use the new D60 in low light conditions and I need to know if VR lens is really helpful in this situation or I can use DX without no problems.
    Anyway I have a steady hand.
    Thanks
  2. SpeedTrap
    SpeedTrap TPF Noob!
    Oct 2, 2006
    1,392
    26
    Edmonton
    Well I think you might have your terminology a bit confused;
    DX is a lens that is specifically designed for crop digital sensors
    VR is Vibration Reduction
    So you can get a DX lens with VR.
    What you should be looking at is faster lenses if you would like to shoot in low light. VR helps, but if you have a lens with an aperture of F2.8 you will be able to shoot with faster shutter speeds and will not need VR.
    The funny thing is, most of the new F2.8 Zoom Lenses come with VR as well.
  3. Bifurcator
    Bifurcator TPF Noob!
    Jun 1, 2008
    3,312
    Japan
    I'm not sure you can actually claim that VR isn't needed if you have f/1.2 or something. It doesn't really work like that - even tho it is kind of related. What about when you want f/22 or f/32 or something? Also what about low light was the meter says f/1.2 is a shutter speed of 1/10 of a second? I see both situations popping up allot. With an f/1.2 or 1.4 lens you might need VR less (maybe) but having fast glass really doesn't eliminate the need for VR.
    On the other hand VR does in more circumstances, eliminate the need for fast (expensive) glass. Especially if it's the Minolta (now Sony) in camera mechanism that's being compared.
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Only when your subjects aren't moving. VR (or IS or the Sony system) only fight blur from camera shake...the slow shutter speeds will still give you blur if the subjects are in motion.
    Another (similar) debate is whether you can get by without fast lenses, if you use the improved high ISO performance of the newer cameras. You can get your shutter speeds up by using ISO 1600 or 3200 or 6400 etc. Although you don't get the same DOF at F4 that you get at F2.8 etc.
  5. Bifurcator
    Jun 1, 2008
    3,312
    Japan
    The Minolta/Sony system also affects subject motion IF the subject in question is filling 90% or 100% of the frame and also when the motion is uniform. For example driving on the freeway it tries very hard to freeze the fences and trees that are whizzing by - it does a pretty good job at it too. Another example would be a flower macro where the flower it blowing around in the breeze. Here's an example of that: http://thephotoforum.com/forum/showpost.php?p=1335122&postcount=4 This flower was blowing in and out of the frame completely. It was on a long stem and rocking in the breeze about a foot or more back and forth.
    Another example would be a close up of a nervous horse's or elephant's head.
    So it does fight both camera shake and subject motion blur. It's won't fight the blur of a bouncing ball in a shorts shot or a fly flying around though (if it's only a small portion of the total frame).
  6. Trenton Romulox
    Trenton Romulox TPF Noob!
    Mar 10, 2007
    2,392
    Maine
    I personally opt for VR if it's available in the lens that I want. But, I mostly only have fast lenses, so I don't necessarily need VR a lot; but I mean, why turn it down? The only reason to opt for a lens that doesn't have VR is when cost is an issue, and that's understandable. I'd say VR is more important in longer (physically) and heavier lenses. That's the big advantage of lens vibration reduction versus camera body reduction is that the camera is rarely what's shaking, it's more often than not the lens itself. So, to answer your question; VR is good, but not 100% necessary. And fast lenses are great, more important than VR, but also not 100% necessary. But, I mean, DOF is important for some types of shots; so keep that in mind when choosing a lens. I definitely rambled a lot here, my bad.
  7. Bifurcator
    Jun 1, 2008
    3,312
    Japan
    I think this is the best equalizer and applies across all situations. f/1.2 at ISO100 has the same DOF as f/1.2 at ISO 3200. :thumbup:
  8. snowalker
    snowalker TPF Noob!
    Nov 4, 2007
    62
    toronto, canada
    Ok, I need to explain exactly my situation...
    A friend of mine has a Nikon D60 + 18-55mm VR. Was taken some picture in Las Vegas in the night time. Anyway there are a lot of lights... Was using higher ISO. So, I have to sell my camera and I want to know if I'll keep my lens 18-55mm DX I can take night pictures at the same quality or is really necessarily to have that lens from kit, 18-55mm VR, like I saw in an offer (Nikon D60 + 18-55mm VR = $620 on BH)...?
    This 18-55 VR how good is in percent in reducing the shakes?
    I don't have enough money now to buy 1.4 or 1.8 lens right now...
    Thanks all!
  9. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    Well you should know its 18-55 dx vr. Its for cropped sensors and has vr. But to the argument, It will probably give you 2, maybe 3 stops of handholdablity so normally if you can shoot at 1/30th of a second, you would probably be able to shoot at 1/8th of a second, maybe 1/4th. But like stated above, remember that if the subject is moving, your still going to have subject blur from motion.
  10. snowalker
    snowalker TPF Noob!
    Nov 4, 2007
    62
    toronto, canada
    Thanks! This is really help me to understand practically the difference between VR and a non-VR lens. Thanks a lot!
  11. photogincollege
    Aug 4, 2007
    706
    Glad to help :).
  12. Sw1tchFX
    Sw1tchFX TPF Noob!
    May 3, 2006
    7,500
    478
    You're getting rid of your D70 for a piddly D60? Are you serious?
difference between dx and vr lens
difference between dx and vr lens nikon
difference between nikon dx and vr lenses
difference between nikon vr and dx lenses
difference between vr and dx lens
dx vs vr lens
nikon 18-55 dx vs vr
nikon dx vs vr
nikon vr vs dx
what is the difference between vr and dx lens
