Noisey lens ???
Discussion in 'DSLR Video Discussion' started by leelyons01, Apr 17, 2012.
  1. leelyons01
    leelyons01 TPF Noob!
    Dec 7, 2011
    9
    Yay a quickly but when filming with my canon 18-55mm or the 55- 200mm I can hear a district crunchy Grindy sizzling sound from inside the lenses but not with other lenses. Any thots. I'm a total beginer btw
  2. Forkie
    Forkie Been spending a lot of time on here!
    Feb 14, 2011
    2,293
    899
    Chiswick, London, UK
    When does it make the noise? When it's focusing or when you're zooming in and out?
    It could just be a tiny bit of grit getting crunched as it turns.
  3. leelyons01
    Dec 7, 2011
    9
    Hmmm it's constant. If its focused and settled the nose remains present and constant :(
  4. Big Mike
    Dec 16, 2003
    33,864
    1,822
    Edmonton
    I'd guess that you're hearing the IS (image stabilization). When you activate the AF, it also activates the IS inside the lens.
    Try turning the IS switch to off, and see if the sounds disappears. With most/all lenses that have IS, you can hear it start and usually you can hear it stop as well (when shooting stills...it may stay active while shooting video).
  5. Overread
    May 1, 2008
    23,801
    4,073
    UK - England
    Does canon make a 55-200mm IS lens?
    IS would be my guess as well for a constant sound like that when the shutter is half pressed. It might be a sign that you need to expand your audio recording setup. If its picking up the IS sound of the lens chances are it might also pick up all those sounds of you changing buttons on the camera or just holding it.
  6. leelyons01
    Dec 7, 2011
    9
    Ahh haa. The i.s. theory sounds pretty likely,
    Can't wait to investigate that Tomorow and report back thanx guys :)
  7. leelyons01
    Dec 7, 2011
    9
    Sorry for the late reply.
    You guys seem to have been spot on with your is theory
    Thanx
  8. fatlip
    fatlip TPF Noob!
    Mar 30, 2012
    26
    Not the lens it's the camera mic, on a 5dmkii you constantly pick up noise manually or not, you never should use the sound from a video shoot anyway, connect a decent mic if your goo ng to do interviews etc .
    I got away with many recordings when I did not have to meddle with the lens
    My experience with almost all lens
    Good luck
