Photo Problems with D70s - CCD Problem?
cumi
Vienna, Austria
Hi there,
has someone experienced such a problem with Nikon D70s (or other models)? The camera started today suddenly to make photos like this:
The brighter parts are badly screwed, the photos are can not be used. The camera is about 6 years old and worked perfectly until now. I didn't do anything unusual with it (cleanig or such).
Any tipps and ideas are warmly welcome.
Yes, others have posted photos that look like that, and from a variety of camera makes and models.
Image sensors don't last forever. Electronic things tend to malfunction all at once rather than deteriorate over a period of time like many mechanical processes.
You can try a 2 button reset, and/or reload the firmware. Otherwise, consult with a repair facility.
I would say send it to be repaired. Either that or look at as an excuse to upgrade.
You can try a 2 button reset...
How should I do it? I don't know about this...
Nikon D70 problem | Gallery
My Panasonic Lumix went out the same way!!! It got excessive moisture inside of it, and the images looked almost exactly like yours!!! I then took the camera and placed it in a coffee can filled with fresh, good dessicant bags for about 10 days...brought it back to life!!!
Best of luck to you!
I talked to Nikon Service in Vienna. The problem is definetly with the sensor. They will replace the sensor with a used one for about 130€.
I have a D70 and this problem occurred for me after 2months.... Nikon replaced the sensor and never had another problem ... This is now a backup, especially shooting strobe at higher shutter speeds. Good luck ....you can find good used ones on ebay that might be cheaper than a repair.
That is the CCD sensor going out. To be honest I'm surprised your D70 lasted this long.
I don't know if you really plan to have it repaired as it can be buy used for about as much or you could really throw money towards upgrading.
