Photoshop CS5 differences
Discussion in 'Beyond the Basics' started by Nimitz, Jul 23, 2010.
  1. Nimitz
    Nimitz TPF Noob!
    Jul 12, 2007
    102
    Indialantic, FL
    Ok, so I just got CS5 installed on my new laptop where I had been running CS3 before & 2 difference icons appear on my desktop ... a 64bit version & 32bit version. So can anyone tell me the difference bewteen these 2? When woukld I use 64bit vice 32bit & can I jump between the two with an image? Thanks
  2. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    64 bit is better but it requires you to have a 64 bit system
    I haven't used 64 bit.
    but it is supposed to be quicker and uses ALL ram (I.e. i have 4gb ddr2 but my comp only uses a max of 2.85 gb.)
    and stuff like that.
    basically, heavy editing = 64 bit
    light touch ups = 32bit
    I do both on a 32 bit system, just takes longer.
  3. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    It's not actually quicker, but yes it does give you access to more RAM which becomes rather important when you have a large file open with many layers.
    As for the original question, this will tell you about everything in a nice bullet pointed way:
    Adobe - Photoshop CS5 : Version comparison
  4. Vautrin
    Vautrin No longer a newbie, moving up!
    Jun 26, 2008
    927
    58
    It changes
    So, in an overly simplified explanation.
    Computers do everything in terms of math -- that transform in photoshop is just a series of addition subtraction multiplication and division by the computer.
    32 bit numbers are 32 digits long (in binary)
    64 bit numbers are 64 digits long (in binary)
    It's faster for your computer to make 1 math operation on two 64 bit numbers then 2 operations on four 32 bit numbers (this is a very simplified explanation)
    In addition, as Garbz mentioned, 64 bit computers can use more RAM (32 bit processors have a 4GB limit).
    So if you have a choice of the 32 bit or 64 bit version, use the 64 bit version.
    But you need to have a 64 bit motherboard and processor combo to make that work. If you don't have that, the 64 bit version will refuse to run.
    You'd have to look at your computers specs to determine if it's 64 bit
    Also, you may see in some programs the option to use GPU / use graphics card. Basically your graphics card / GPU, is an additional processor, and some image editing programs can take advantage of it to speed up processing
  5. MrsMoo
    MrsMoo TPF Noob!
    Nov 10, 2008
    209
    Fife, Scotland
    I use the 64 bit version, as we just updated our computer. I'd say it was worth going for that one over the 32 bit :)
  6. KmH
    Apr 9, 2009
    40,733
    5,587
    Iowa
    The reason 32-bit computers can only have 4 GB of RAM, is addressability.
    The range of integer values (addresses) that can be stored in 32 bits is: 0 through 4,294,967,295 or 4 GB. (1 byte = 1024 integer values.)
  7. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    : - minus system reserved space of around 700-800mb so you can in reality only address 3.2GB without PAE (Physical Address Extension) enabled in 32bit mode, and when you enable PAE you take a performance hit.
  8. Nimitz
    Nimitz TPF Noob!
    Jul 12, 2007
    102
    Indialantic, FL
    perfect, thanks ... my new laptop is 64 bit so I'll just use that version
  9. MohaimenK
    MohaimenK TPF Noob!
    Nov 13, 2008
    2,583
    11
    In between her...
    if you can use the 64 do that. btw, how are you liking the content aware feature??
  10. sovietdoc
    sovietdoc No longer a newbie, moving up!
    Jun 12, 2010
    1,140
    75
    rest of the world
    content aware fill is the best thing ever to happen in photoshop. I don't really know about anything other "content aware" besides the scale feature, which is useful at times, but not as much as CA fill.
  11. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Content aware fill is hit and miss. It works better than the old spot healing brush tool, but I still find myself reaching for the healing brush. When it works it works well, when it doesn't the healing brush may work.
    It doesn't seem better in that regard in my opinion, just different and between the two tools you get a pretty high success rate.
