Photoshop Extract tool
Discussion in 'Beyond the Basics' started by bogleric, Nov 19, 2007.
  1. bogleric
    bogleric TPF Noob!
    Oct 23, 2003
    931
    North Carolina, USA
    Has anyone tried using the photoshop extract tool to remove the background from a picture. I have a client that needs to use an image in a publication that was taken with a blue based background.... client absolutely loves it, and now the client is being featured in a professional publication. However, the publication requires a different color background and the client does not want to re-shoot. Keep in mind it has been almost a year since the shot was taken and the client is willing to pay for the changes.
    This is working quite well except for some areas in the hair and the glasses. I find with the hair it is easy to get a halo and quite difficult to eliminate without giving a hair cut.
    Would anyone be willing to offer some tips and tricks for this kind of change?
    Thanks....
  2. bogleric
    bogleric TPF Noob!
    Oct 23, 2003
    931
    North Carolina, USA
    please note... this was not taken with a chroma background as this was never the original intent.
  3. Stranger
    Stranger TPF Noob!
    Jul 9, 2007
    495
  4. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Extraction is one of the basic techniques for a lot of Photoshop work. There are probably 100,000s of tutorials on the internet already.
    You can use the extract tool...but there are many other ways to get started. As noted, with a simple background, you can use the magic wand or select color range to select the background. I also suggest using a layer mask to fine tune the selection at a high magnification.
  5. The Phototron
    The Phototron TPF Noob!
    Jun 26, 2007
    948
    Use pen tool, a wacom tablet, and a **** load of patience. And just start drawing paths around the subject. There's no easy way out of this one, especially if you're going to extract hairs.
  6. Sideburns
    Sideburns TPF Noob!
    Aug 14, 2007
    2,796
    Windsor, Ontario
    I use masking usually...but sometimes I use the selection tool in CS3 which works well.
  7. nossie
    nossie TPF Noob!
    Oct 15, 2007
    794
    Dublin, Ireland
    If it's just a colour change then add a hue/saturation layer and just change the colour for the blue channel
  8. bogleric
    bogleric TPF Noob!
    Oct 23, 2003
    931
    North Carolina, USA
    I am familiar with the basis of the extract tool.... I was just hoping for something a little bit quicker than my current process.... guess not.
    Thanks for the input
  9. Jon, The Elder
    Jon, The Elder TPF Noob!
    Jul 10, 2007
    376
    Southeastern Michigan
    Yup, I know the feeling. Seems that anything with detail takes a lot of patience and hard work.
  10. kaiy
    kaiy TPF Noob!
    Nov 27, 2007
    69
    If you are working in layers, outlined person in one layer, new background underneath, I usually eliminate halos by duplicating the person layer and placing the copy between the original and background. Set the copy layer to multiply (turn off main person layer and play with the copy layer opacity so the hair edge doesn't get too dark.) Turn on main layer, and erase the haloed edges with a brush set at 10-30% opacity. Erase the hair edge slowly to get a nice soft outline, allowing the multiplied edge to show.
    For a better, more editable edge, use a layer mask. If you "erase" too much, then you can just fix the mask and put erased edges back. The multiplying layer will blend the hair with the new background. If you need to define strands of hair, a tablet and pen are great tools.
  11. Fiendish Astronaut
    Fiendish Astronaut TPF Noob!
    Aug 12, 2006
    324
    London, UK
    Duplicating the extracted layer and then merging fixes lots. Then use the History Brush Tool around the edges to fix the image further.
    Hair is tricky, I just need use a thick highlighter when your tracing the subject in extract. Then afterwards zoom in and paint, clone etc to clean up so the hair works against the background.
  12. stubbsk
    stubbsk TPF Noob!
    Nov 25, 2007
    112
    Manchester, England.
    masking is a lot better. you can spend time refining it.
