Photoshop HELP!!!!!!!
Discussion in 'Photography Beginners' Forum' started by obx, Sep 22, 2010.
  1. obx
    obx TPF Noob!
    Mar 4, 2010
    73
    New Jersey
    Hello,
    When I go to save my work on Photoshop and I change the format to JPEG and make it 8 Bits the little box comes out and it reads as follows:
    "Could not save a copy as (%#%#^%.jpeg) because write access was not granted"
    How the heck do I grant access to SAVE!!!!!!!!!!
    I am running Photoshop CS4 if that helps.
    Thank you for your help in advance.
  2. XCountryGuy
    XCountryGuy TPF Noob!
    Sep 18, 2010
    47
    Ontario
    Try saving to a different folder or a different file name. Failing that, you could flatten the image, select all, copy, start new file, paste, then try saving that file.
  3. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Check the original file and make sure that you haven't got it set to "read only" in its properties
  4. obx
    obx TPF Noob!
    Mar 4, 2010
    73
    New Jersey
    Not working!!!!
  5. obx
    obx TPF Noob!
    Mar 4, 2010
    73
    New Jersey
    How do I get to its properties to check if its "read only"
  6. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Go to the folder the file is in and open the folder up - select the file with a right click and from the menu select "properties". You should then get a little window and somewhere near the bottom will be "attributes" if read only is ticked you will have to untick it. Sadly though this might not work with the file already opened in photoshop so you might have to close (and lose you edits) and then repeat again once read only is unticked (if this is indeed the problem)
    edit - you might also try changing the file name when you save it that might get around the read only clause
  7. obx
    obx TPF Noob!
    Mar 4, 2010
    73
    New Jersey
    Not working!!!!!
  8. Bitter Jeweler
    Bitter Jeweler Been spending a lot of time on here!
    Apr 27, 2009
    12,984
    4,976
    Cleveland, Ohio
    Try going to Adobe product support, or Photoshop forums.
what does write access not granted mean
write access was not granted mac
