Photoshop Order of Operations
Discussion in 'Graphics Programs and Photo Gallery' started by AverageJoe, Feb 28, 2009.
  1. AverageJoe
    AverageJoe TPF Noob!
    Sep 16, 2007
    918
    4
    Minneapolis, MN
    I'm wondering if it matters when I do what, here's what I typically do in the order I do it:
    1. Open JPEG
    2. Crop subject
    3. Sharpen
    4. Sharpen Edges
    5. Levels or Auto Levels
    6. Resize image
    7. Save
    What's everyone's take? Does it matter?
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,186
    940
    Woodbridge, Ontario, Canada
    I would change step 1
    1 Open RAW file
    or
    Use Canon utility to convert RAW to TIFF
    1 Open TIFF file
  3. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    Sharpening should be the last stage of your editing - it can cause your problems if you sharpen first and then start editing things like levels.
    Further when resizing you lose sharpness in a shot - so before resizing perform your sharpen - then after resizing sharpen the shot again - chances are you will need a lesser amount of sharpening the second time around.
  4. AverageJoe
    Sep 16, 2007
    918
    4
    Minneapolis, MN
    Every other weekend I shoot about 100-200 shots of cats and dogs for a animal rescue, managing that many RAW files would get annoying fast considering I'm sending the agency files that are about 650 pixels wide.
    Overread, I'll take that into consideration and try some samples, thanks.
  5. Honu
    Honu TPF Noob!
    Sep 28, 2008
    63
    Monrovia, California
    I can't remember where i found this list but I've been using it -
    • Crop
    • Contrast
    • Brighteners
    • Color
    • Defects
    • Sharpness
    Any thoughts on this list?
    I just don't know where noise correction would fit in - would that fall under defects?
  6. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    For me I would move crop to just before sharpening and I would put colours higher up on the list. Cropping very much changes the view on the image and can be well used to remove waste space or to draw attention to a key element - however sometimes you need to see the shot as it is finished in editing to fully understand where it is best to crop a shot.
    Colour also needs to really be hammered out near the start of editing. For me I use RAW to try to set white balance to the right amount -- I then use curves/levels to correct colour casts in the shot. I think its important to do this first before you look to boosting or reducing things in contrast, brightness and saturation.
    Noise correction for me is just before sharpening - its not really going to majorly affect the end result on the other edits and sometimes things like contrast editing or curves can lead to more noise being made in a shot. In those cases it might be better to reduce noise first so as to reduce the boosting effect of other edits. I try not to use hardfast rules amd be adaptable to what I get in each shot.
    Also note that (when working properly) I will save a shot as a PSD (or a TIFF) before noise and sharpening - and then after that I will flatten the layers and then use 2 layers and layer masks to selectivly reduce noise in the background areas and to boost sharpness in the infocus areas - sometimes the main subject areas will get a lesser noise reduction as well if there is bad noise in the shot. One does not need to sharpen background noise just as one does not always need to remove noise (and also reduce sharpness) from the main subject areas
  7. abraxas
    abraxas No longer a newbie, moving up!
    Aug 15, 2006
    10,417
    9
    It matters. Try;
    1, 5, 2, 6, 3, 4, 7
  8. Captain IK
    Captain IK TPF Noob!
    Dec 5, 2008
    630
    Windsor, ON. Canada
    Should levels (contrast, brightness and colour temp) be adjusted while still in RAW format?
  9. Miami Photographer
    Miami Photographer TPF Noob!
    Mar 6, 2009
    18
    Thanks for sharing!!
  10. Overread
    May 1, 2008
    24,073
    4,172
    UK - England
    I think its best to adjust as much in RAW as you can - the limit with RAW (at least with my RAW editer I am not sure of others) is the fact that any changes are global - they affect the while image - whilst in the editing program you can be selective as to what areas get what editing. If you can edit it in RAW then do it
  11. photogincollege
    photogincollege TPF Noob!
    Aug 4, 2007
    706
    Grand Rapids, Michigan.
    Mine is.
    1. Open image.
    2. Adjust white balance, open in photoshop.
    3. Copy background (non destructive editing)
    4. Crop if needed.
    5. Curves, 1 for luminosity, 1 for color.
    6. Any dodging/burning etc. here.
    7. Unsharp mask.
    8. Save image.
  12. DRoberts
    DRoberts TPF Noob!
    Apr 18, 2008
    780
    Springfield, Missouri
    I agree with Overread on this. Do as much correction as you can to the original image before crop, resize and final sharpness.
    My order is...open file is obvious so I won't include that in my list.
    1. duplicate file and work on copy...
    2. levels
    3. curves
    4. final color adjustments
    5. exposure/contrast fine tuning
    6. crop
    7. resize
    8. sharpening/blurring whichever I'm doing...
    9. details ie...cloning, healing, etc...
    10. optional conversions
color correction photoshop order of operation
order photoshop editing
photo shop edit order list
