picture mess up on OLD slr
Discussion in 'Beyond the Basics' started by Dan39, May 12, 2006.
  1. Dan39
    Dan39 TPF Noob!
    May 12, 2006
    14
    I took this picture with my old Miranda SLR(scanned the photo) and I dont know why, but the picture looks nice except that its got this box(you can see where it starts at top and bottum of pictures) of whiteness shadows. It is pretty easy to see even in the thumbnail. I am not sure why this happened. Does anyone know why or what causes this, or have any ideas at all? The only user-related problem I can think of was having the color/metering setting to Off, but I am pretty positive it would not do this, but just make the whole photo look kinda blurry and dark or something like that. And is it possible there is some way in photoshop that someone can make it look better?
    This is like the only photo that has this whitness stuff this bad. Some other photos have small little showings of it in the corners, but they are not too noticable. Only a few photo's have this problem, most are totaly perfect.
    [​IMG]
    Help!, thanks much
    well, heres the best i could do for trying to fix it...
    im not the best in photoshop
    [​IMG]
  2. harlantk
    harlantk TPF Noob!
    Apr 22, 2006
    12
    Colorado
    Hey Dan,
    I will share my thoughts and experience of white shadows and streaks using a scanner. I am just a new kid on the block so remember others will have a better scope of this than I.
    I had this happen a long time ago, using glossy photos, the gloss reflected the light back at me, causing the white flashing. I only had to move the photo to a different scan location to get around it then, but think I got lucky. I do not know how to de-gloss a photo for scanning so in that department, am at a loss. So if it is caused by a gloss photo, hopefully moving it around will help, or someone else has a better idea.
    I had a similar issue to this once as well, but was not a glossy photo, and I determined that it was actually my scanner, giving up its ghost. I scanned a grey card to see how clean my scanner was operating, and found a lot of white lines (tears) in the image. It wound up being hte power supply was dying, and I just replaced the scanner. Then a few weeks later the new scanner started to white ghost along the edges, and I felt doomed really. But found that I had to move my scanner away from the monitor who was inducing hte fog or ghost by its radiated field.
    I hope this is helpful for you and good luck!.
    Tim
  3. Dan39
    Dan39 TPF Noob!
    May 12, 2006
    14
    the white shadow is on the actual photo itself, and i can see it on the negative also...sry if i confused you
    at 1st id think over exposure or something, but if you look at the white shadow on the bottum and then right below it the picture is perfectly fine
  4. 2framesbelowzero
    2framesbelowzero TPF Noob!
    Mar 24, 2006
    300
    Possibly light entering the camera from the eyepiece ?
    Try making a picture with it taped-over and see.
  5. Dan39
    Dan39 TPF Noob!
    May 12, 2006
    14
    o yes that may be the problem, though when i was taking that picture i was looking through the eyepiece, but the sun was right behind/above me and it may of peaked through the top crack
    maybe ill do some tests with light going through eyepiece to see if it makes the same effect
    in the manual for the camera it said that when using the self-timer if the eyepiece isnt covered any light that comes in can mess up the photo
  6. Mitica100
    Mitica100 Moderator Staff Member Supporting Member
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Another possible explanation is the seals around the camera door are old and allow light to seep in. After you do the eyepiece test, run some black duck tape around all edges of the door and shoot normally. See if the streak is still there. Don't forget though to take the tape off the eye piece first so you know where's coming from, if you shoot on the same roll.
  7. 2framesbelowzero
    Mar 24, 2006
    300
    Love that avatar mitica100 :thumbup: :lol:
  8. Torus34
    Torus34 No longer a newbie, moving up!
    Jan 26, 2006
    2,117
    37
    Tottenville, Staten Island, NYC USA
    Light leak.
  9. Dan39
    Dan39 TPF Noob!
    May 12, 2006
    14
    ok thnx guys, i think some light leaked in somewhere. ill grab a roll of film soon and do some tests =]
    hopefully its not any of the seals on the camera door, and just the eyepiece letting some light in
  10. Mitica100
    Nov 11, 2003
    9,777
    50
    Ahwatukee, AZ
    Dan, door seals are the easiest to fix. If turns out to be door seals at fault let me know and I'll send you some foam and installation directions so you can do it without spending any money.
  11. Matt_Gill
    Matt_Gill TPF Noob!
    Mar 26, 2006
    47
    Nono! if you scanning glossy prints it will be the light in the scanner reflecting.
  12. usayit
    usayit No longer a newbie, moving up!
    Nov 15, 2003
    9,523
    346
    North New Jersey, United States of America
    I agree with Mitica. Looks like the foam seals around the back film door. If the light seal foam is sticky then its time to change it. Pretty easy to do. Practically every camera in my collection has needed those seals changed. You can also purchase some from "cameraseals.com". They send you enough to do several cameas.
    I've used bamboo skewers shaved and cut to my liking as sort of a "soft" chisel to scrap off the old stuff.
