Post-Processing Raw
Discussion in 'Photography Beginners' Forum' started by calvini, Jan 24, 2008.
  1. calvini
    calvini TPF Noob!
    Jan 2, 2008
    10
    Seeing that I just got into this fantastic world of photography, and having much to learn, I was wondering if you all could give some advice to a beginner for post-processing raw files? Such as what do you look for in adjusting a a Raw picture?
    I've heard alot about white balance and tones, but what are the normal processes one would take in post-processing pictures? If they have a standardised workflow at all.. Or do you tweak each picture individually?
    There's lots to play around I admit that, and when trying to process a picture I find myself say an hour playing around with colours on a single picture!! And obviously I can't spend that much time on a single picture having say hundreds to process.
    I like how the good photographers process their images and boy do their photos "pop". I'd like to achieve that level and if there's any headers and pointers that would guide me to that direction, I'd really appreciate it.
    Cheers.
  2. Mav
    Mav TPF Noob!
    Jan 1, 2008
    1,457
    I use DxO software. The interface is a little odd, but after you get the hang of it you can FLY through a ton of images. And you don't need to bother with RAW for the most part either. You can make pretty aggressive changes even to JPG, including WB adjustments and it'll look just as good as RAW. I do tweak hundreds of files at a time individually, and then set the computer to run all of the adjustments in its batch process mode and then walk away. Come back later and all of them are done.
  3. ThePup
    ThePup TPF Noob!
    Oct 12, 2007
    108
    Western Australia
  4. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Batch processing is great for images that all have a consistent look and feel to them. Maybe studio shots where exposure is the same or wedding shots where the photographer has shot in manual to give a consistent look.
    When starting out, I edited every shot individually and enjoyed the hours spent in front of the puter.
    Plugins like Dxo are nice but i prefer shooting RAW and using lightroom to edit my images. Some are batch processed some individually and all done very quickly.
    The more you do, the more you'll learn, the quicker you'll get.
    Enjoy it :)
  5. nicfargo
    nicfargo TPF Noob!
    Jan 4, 2008
    369
    Nebraska
    I use lightroom to process. At first I was very slow...didn't really know the software and how it reacted with RAW. Now I am very quick because I know exactly what needs to be done to a picture to get it to look the way I want. I usually do individual processing. If I can get away with batch I do, but I like to play with my settings way to much to be able to do that :)
  6. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Shooting many wedding portraits (groups and individual images) in the same lighting and using manual control allows me to edit many images at one time however I may choose a few to do extra work to (B&W, Sepia, Vignette etc) and all this can also be done in lightroom which is great.
  7. MACollum
    MACollum TPF Noob!
    Dec 13, 2006
    404
    Oklahoma
    I tend to take several versions of the same picture with different camera settings, trying to fix something, etc. Usually I do what someone else mentioned; I'll just pick a few that I want to play with and have at it.
  8. calvini
    calvini TPF Noob!
    Jan 2, 2008
    10
    Oh wow, cheers guys for all pointers! So I guess majority would play with only some that are worthy of playing with and with the rest just adjusting the white balance? Do you/ should you change saturation/contrast per image or just run them through a batch process or leave it as is if the picture turns out good enough?
    I hear alot about unsharp mask to sharpen pictures post-processing. Should I unsharp mask each picture which I then convert from Raw to say tiff/jpeg?
    Wow.. lots to learn.. like lots..
  9. Tayfun
    Tayfun TPF Noob!
    Nov 19, 2007
    139
    Istanbul/Turkiye
    Hi;
    I use Adobe Camera Raw for post proccessing. I adjust White Balance, exposure if needed and set sharpness to zero to give sharpness later in photoshop. I don't like to adjust color balance, or brightness because I like to view what I see naturally but sometimes color adjustments give out nice results. But main purpose for me to Raw Shooting is White Balance, sharpness, and exposure (if needed) adjustment.
  10. EOS_JD
    EOS_JD TPF Noob!
    Feb 15, 2007
    1,698
    Seriously by a book on digital workflow. there is a lot to learn. Sharpening is normally required on a digital raw file and sharpening should be the very last thing you do in your digital workflow.
  11. calvini
    calvini TPF Noob!
    Jan 2, 2008
    10
    Can you recommend me one that is good for purchase? I've not heard much here about digital workflow books. I have recently bought only the Understanding Exposure and the Field Guide for my camera as they are highly recommended.
    Any recommendations would be greatly appreciated
  12. confucious
    confucious TPF Noob!
    Aug 16, 2007
    125
    Ottawa, Canada
    You said you play for hours with pics and so it's daunting when you've got so many. I know just what you mean, I'm sure everyone here does cause we all started at the beginning too. I think it takes you hours as you're new to the software, the colours, contrast, and light in your pics. As you get accustomed to it (experience is the only way) you become familiar with what will give you the results you want right away. Toying becomes something you do for fun, but for the majority you will know the direct route to the result you want.
    Good luck and have fun!
