astrostu
I shoot for the stars
- Joined
- Aug 1, 2006
- Messages
- 673
- Reaction score
- 17
- Location
- Boulder, CO, USA
- Can others edit my Photos
- Photos NOT OK to edit
We have a total lunar eclipse coming in just under two weeks. The thing is, I've "done" lunar eclipses now and grown jaded with the up-close moon-fills-the-frame thing and very, very, VERY slowly (over 5-6 hrs) seeing it change colors/shades/brightness. And dealing with mounts that track the moon that, if off by a teeny bit, result in smearing because I'm using a 1280 equivalent lens.
What I really like these days is the shots that show the stars, partly because a total lunar eclipse is the only time you can photograph a moon and stars in the same shot with the same exposure. And, I have a fairly good landscape near me, the moon will arc over a valley, start eclipsing maybe half-way through, and then set while still partially eclipsed over some mountains (assuming I have my geometry right, I need to watch the path the day before).
The question is, how should I do this? Ideally, I'd have two cameras. But, I bought a 14mm f/2.8L this year which shot (ha!) my camera budget, and I decided awhile ago that my 7D will have to do until the 5D MkIV comes out.
My intent is to do a timelapse. In the past, when using the super-dooper-closeup lenses, I've done it once every 5 minutes. If I want to show the moon's motion over the landscape, I'll probably need to shoot at least once a minute to make it smooth. With a 5hr 15min event, once every minute = 315 frames = only 10.5 seconds at 30fps, so I'd probably want at least every 30 seconds. To do slow-moving clouds, you need once every 10 seconds. I should probably experiment the night before ...
My 14mm will almost get the whole field of view, but not quite. I'll need to check exactly how much the morning before. But, the moon's a tiny spec in a 14mm lens. My 24-70 gets a much narrower view, so I'd have to move it and I don't think can get the foreground and moon in the same shot when the moon is highest. But it would allow me to zoom in, and do a quick-swap between shots to the 70-200 to get even closer. Thoughts on focal length / lens(es), keeping in mind I want a cohesive and smooth timelapse?
What about exposure and post-processing? Many of us know and politely remind others that the moon is really bright and night is really dark. You need a maximum of 1/60-sec for a full moon, usually closer to 1/250 depending on atmosphere and f/# (and ISO). But during the total eclipse, it dims by a factor of around 50,000 (last lunar eclipse, I calculated a dimming of closer to 62,500x). And, I want to get the landscape. The vision in my head is a movie showing a brightly lit landscape with a glowing moon where you can just barely make out detail, and then the landscape dims as the moon turns red and travels through the stars for an hour, to start to emerge just as it sets. Beautiful movie in my head, but I have no idea how to pull it off when I'll need to somehow combine 1/250-sec with a 5-10-sec shot, and a few hours later be pulling 10-second shots at ISO 800 so the moon doesn't move in the frame. And if I'm using 70 or 200mm at that point, I actually probably can't go longer than 5 seconds without seeing trails. Thoughts?
