Question for digital camera users....
Discussion in 'Beyond the Basics' started by LeeDogg, Mar 6, 2004.
  1. LeeDogg
    LeeDogg TPF Noob!
    Feb 16, 2004
    32
    Canada, Alberta
    What settings do u all use in terms of resolution? I use the largest I can on mine which is 2048x1536, but what I really would like to know is if there is a big difference betweeen the quality modes such as, Normal, Fine and Super fine. I was using Superfine and tried using Fine without noticing much difference, is there a time to use low quality verses high? I'm very new to the hobby and appreciate any info or recommondations, thanks, Lee
  2. urameatball
    urameatball TPF Noob!
    Aug 18, 2003
    124
    Toronto, Canada... EH?
    for most cameras:
    superfine - no compression
    fine - little compression
    normal - high compression
    basically, with jpeg compression, you will only notice it around contrast color edges. Like if you're photographing a black piece of paper on a white background, you'll see that there's little tiny fragments around the edges of the black paper. Compression doesn't look too nice on gradient colors either, if compression is set too high, you will see descernable chunks of color rather than a smooth gradient.
    resolution:
    I always use the highest I possible setting (same goes for file quality).
