Restoring Photos
Discussion in 'Beyond the Basics' started by Easy_Target, Jun 26, 2009.
  1. Easy_Target
    Easy_Target TPF Noob!
    Aug 4, 2007
    380
    Not sure if this is the right place, but here goes.
    I was in the basement and came across some family photo albums and decided to look through them. I found some that were of my grandparents when they were in their mid-30s (1940s-ish). I've started to scan them and digitize them as a surprise gift for my parents/aunts&uncles.
    I came across one photo that's particularly problematic. It has some fire damage to the right side, but I can fix that in photoshop. What's more troublesome to me is the fact that it's actually THREE photos.
    There's one photo that's stuck to the back of the first photo. Emulsion and paper is starting to separate in some parts. Then there's another photo on top of that one, except this one is mostly emulsion. The majority of the paper backing has worn off.
    Is it possible to have the two on the back removed from the first and each other? Obviously without damaging any of the photos.
    Print: Black and white
    Emulsion type: Unknown
    Paper manufacturer: Unknown
    Paper type: Unknown
    I had to underexpose a good amount because of the lighting in my room.
    [​IMG]
    http://tinypic.com/r/9ihg5h/5
  2. dxqcanada
    dxqcanada Been spending a lot of time on here!
    Dec 4, 2008
    6,186
    940
    Woodbridge, Ontario, Canada
    Place photo's in a warm water bath ... until they separate.
    Do not force apart ... they will do that on their own.
  3. Easy_Target
    Aug 4, 2007
    380
    I was considering the warm water bath, but I was reluctant because I don't know the stability of the photo & the emulsion and paper. I don't want to risk damaging irreplaceable memories more than I already am [by taking it out of storage and actually handling them].
  4. dxqcanada
    Dec 4, 2008
    6,186
    940
    If the emulsion got wet ... then dried in contact with the paper backing of the other print ... then the only way to do this is by softening the emulsion again by soaking it.
    This advise was given to another Poster with the same problem.
    For him, the prints separated in the bath with no damage to the prints.
  5. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    You'll be in luck because of the age of the photos. The process of making the print involved exposure, developing, stopping, fixing, and then washing, all of which are liquid.
    Use water at a bit above room temperature, and then hang to dry. Try not to touch the photo emulsion while it's still soft and fragile.
  6. Easy_Target
    Aug 4, 2007
    380
    The first photo is still in good shape, but the other two are in poor shape. How would I treat those two? Particularly the one that's all the way on the top layer, which is all emulsion with only a little bit of paper left.
    What should I use to back the one that's only emulsion? Is there anything I can do to reinforce the second one which still has emulsion and paper, but is separating?
  7. lucerojamie
    lucerojamie TPF Noob!
    Jun 27, 2009
    good idea up there!
    I remember ruining one of our family photo by forcing it to separate from one other old picture hehhe...
    I don't forget my grandma's face. :)
