SD cards for my Nikon D60
Discussion in 'Photography Beginners' Forum' started by amara_shadow, Jul 1, 2008.
  1. amara_shadow
    amara_shadow TPF Noob!
    Oct 30, 2007
    89
    Wellington, New Zealand
    This is probably one of the silliest questions, but if I don't ask I won't find out right?
    Will my D60 take any size SD card? I am going overseas in 3 weeks time, and am looking at getting an 8GB card.
    Thank you :)
  2. Tyjax
    Tyjax TPF Noob!
    Jul 23, 2003
    483
    Akron, OH
    Unless you have an odd d60 I beleive the D60 is SDHC compliant. Meaning Yes you can use up to the top of the line 16gb sdhc cards. I use a 4gb and a 8gb card in my d80.
    All good.
    JT
  3. sabbath999
    sabbath999 No longer a newbie, moving up!
    Apr 11, 2007
    2,699
    68
    Missouri
    There is no "odd" D60... they all take both SD and SDHC cards, certainly the 8GB card in question.
  4. amara_shadow
    Oct 30, 2007
    89
    Thank you for your replies :) I just wanted to double check before spending the money.
  5. Tyjax
    Tyjax TPF Noob!
    Jul 23, 2003
    483
    Akron, OH
    Hmm, I don't know about the d60. Ergo the "I dont know" but the d80 already has two firmware versions that make some significant differences. By odd I meant "possible differences". Have there been NO firmware updates for the d60? I will check. I have no idea.
  6. sabbath999
    Apr 11, 2007
    2,699
    68
    Missouri
    Firmware doesn't matter. A camera is either hardware able to use SDHC or it is not.
  7. Tyjax
    Tyjax TPF Noob!
    Jul 23, 2003
    483
    Akron, OH
    You are wrong. http://www.engadget.com/2006/09/09/sdhc-enabling-firmware-updates-for-pentax-casio-cameras/
    I am in the tech field professionally. Tech I know.
    The hardware for SD and SDHC follow the same standard. The electrical standards and intelligence in the ASICs determine the SD/SDHC compliance.
    Wikipedia for starters:
    The format has proven to be very popular. However, a change in the format, while allowing capacities greater than 4 GB (SDHC), has created compatibility issues with older devices which cannot read the new format. Since SDHC format cards have the same physical shape and form factor as the older format, this has caused considerable confusion for consumers.[1][2] SDHC cards require an SDHC capable device firmware, generally not found with older devices.
    If you need whitepapers I have those on my work computer.
    Peace out.
  8. sabbath999
    Apr 11, 2007
    2,699
    68
    Missouri
    I am often wrong. :)
  9. Tyjax
    Tyjax TPF Noob!
    Jul 23, 2003
    483
    Akron, OH
    Me too. Just ask Mrs. Tyjax
  10. TamiyaGuy
    TamiyaGuy No longer a newbie, moving up!
    Jun 25, 2007
    1,078
    Chelmsford, UK
    According to a neat little chart I read, the Nikon D40 can use up to 8GB SDHC cards, but not 16gb. If you want to get a 16gb, certainly check at a local store to see if it will work before buying it.
    But an 8gb card should be no problem. Enjoy!
    Edit: Sorry, I forgot to mention that the Nikon D60 is, essentially, exactly the same as the D40 firmware-wise. However, things always change, so check :D
  11. hXcPhotography2
    hXcPhotography2 TPF Noob!
    Jul 2, 2008
    8
    Lenoir, NC
    Well I got two 4g SDHC cards for the price of one 8g so thats what i use in mine.
best card for nikon d60
best sd card for nikon d60
d60 sd card
nikon d60 requires how many gb for sd card
nikon d60 sd card
nikon d60 sd card compatibility
nikon d60 sdhc support
sd card nikon d60
type sd card nikon d60
