self portrait of schumionbike
Discussion in 'General Gallery' started by schumionbike, Apr 12, 2007.
  1. schumionbike
    schumionbike TPF Noob!
    Mar 9, 2007
    1,083
    Houston, Texas
    [​IMG]
    Camera make: EASTMAN KODAK COMPANY
    Camera model: KODAK EASYSHARE Z710 ZOOM DIGITAL CAMER
    Date/Time: 2007:04:10 17:11:15
    Resolution: 480 x 640
    Flash used: No
    Focal length: 17.5mm (35mm equivalent: 105mm)
    Exposure time: 0.050 s (1/20)
    Aperture: f/3.2
    ISO equiv.: 400
    Whitebalance: Auto
    Metering Mode: matrix
    Exposure: Manual
    Exposure Mode: Auto bracketing
    Comments and Critiques would be great!!!
    Anyone think it's too tight of a crop?
  2. schumionbike
    Mar 9, 2007
    1,083
    Houston, Texas
    bump =)
  3. julius
    julius TPF Noob!
    May 18, 2006
    133
    Hey schumionbike
    I think this is a good attempt at a self portrait.
    Why did you choose to set the exposure manually on this shot? IMO the exposure is a little long to be hand held (the image isn't as sharp as it could be).
    There is a rule of thumb that can be used to make sure your photos are sharp. Generally, you should not take a shot by hand slower than 1/focal length. ie for this case the length is 105mm, so to get a sharp image you should use a shutter speed of around 1/105 seconds or faster. This shot is only taken at 1/20 seconds.
    Upping the ISO level and/or dropping the aperture (probably not the aperture in this case) will speed up the shutter speed as you probably already know.
    Also, if your camera has a self timed option and you have access to a tripod this may be another way to take a self portrait and the image will be sharper this way too.
    Nice work
  4. schumionbike
    Mar 9, 2007
    1,083
    Houston, Texas
    Hey thanks for the reply. You point out something that I didn't notice before too. I knew about the rule of the thumb but I didn't realize that my shutter speed was that slow compare to my focal lenght.
    I set the exposure to manual basically for learning purposes. The ISO on this camera is max out at 400 and aperture could go 2.8 but sometimes it can't. I have no idea why. I will try some of the auto mode later to see how the camera does it.
    I don't have a tripod so that's just unfortunate. Thanks for the reply though, I will keep in mind these tips next time I shoot anything.
  5. newrmdmike
    newrmdmike TPF Noob!
    May 8, 2006
    2,107
    it varies.
    the reason your camera can't always go to f/2.8 is because when it zooms in it can no longer let in that much light, its a characteristic of cheaper lenses.
  6. schumionbike
    Mar 9, 2007
    1,083
    Houston, Texas
    ah, cool, you learn something new everyday, thanks newrmdmike.
