Some flowers (300mm + close up lens)
Alex_B
Europe 67.51°N
just some test shots I did a couple of days ago with a 300mm lens plus a close up lens screwed onto it (currently my only macro option).
composition wise they are not brilliant ...
1:
2:
3:
4:
f/25 on all of them except #3 which is f/18
full frame in both senses: almost zero cropping in postprocessing and also taken on a full frame 35mm sensor ;)
These look pretty good. So about how far away were you when you shot these?
not too close as it is a 300mm lens ... I would guess around 20-30cm.
in terms of macro these images are pretty close to 1:1.
The blossoms in the last ones are really tiny ... they are measured in a couple of mm only.
The second is by far my favorite...the only thing that bothers me is the blue blurb happening on the right ;)
Impressive detail on all of them :)
Yeah, I was wondering if that close up lens affected the focusing distance at all.
not bad mate not bad at all
thanks all :)
Nicely done.....I like the last two with the DOF.
You shoot with a Cannon and they're that good?????? :lol:
well, consider this an accident :p Even with a cheap Canon you can do it, if you are lucky ;)
