Assuming you are using a "35mm" DSLR, than select 'Spot' from your metering modes and position the area in question in the centre of the viewfinder or on the active metering point if you have that option.[/QUO
in spot metering you have to focus, right. how do you focus a dark area or smooth shiny surface.
in spot metering you have to focus.
