thereyougo!
- Joined
- Jun 1, 2010
- Messages
- 2,316
- Reaction score
- 1,992
- Location
- UK
- Can others edit my Photos
- Photos OK to edit
I guess a lot depends on what you plan on doing with the camera. I prefered the Nikon system myself because I shoot a lot of stuff in lower lighting conditions and that's a place where Nikon has an edge.
However in most shooting situations to be honest the differences between Canon and Nikon really aren't that huge. Sony I don't really recommend unless your going mirrorless, wanting something light weight and don't mind having a very limited lens selection.
If everything your shooting you can shoot with say a 16-50mm lens and you really need the portability, then it might be a good option. But for the most part I don't recommend Sony because of their track record.
Sony has this history of coming up with ideas that sound really great - and then never really following through on them. With my Nikon I can buy a $1000 or $2000 lens today and I'm very confident that 10 years from now I can still use that same lens on their latest and greatest camera body should I choose to upgrade.
I just don't have that confidence with Sony. Right now their big thing is their new E mount.. but lets be honest, they never really did throw that much support behind their older A mount. And I have no idea if their E mount will still be supported 5 or 10 years from now.. for all I know they'll come up with something new and more or less abandon the E mount.
So if your looking for a very portable system that will likely only have a very limited set of lenses and that lens set works for you, then yes maybe Sony might be worth a look.
But if you don't mind carrying a DSLR then I would strongly urge you to stick with either Canon or Nikon. You can get a ton of lenses for each, the used market is very strong for both, and all in all your looking at a lot less money for a lot more capability as a result.
There's an awful lot of generalisation here about Sony. The E mount has been around for some years now. First of all with crop and then with FE - the Full frame version of E mount. You can use crop E mount on FE but in the same way as APS-C on Nikon will work on a FF F mount.
There has indeed been some discussion on the future of the A mount, and this is still under question. But it's not really Sony's mount, is it? It was Minolta's. Sony inherited it from Minolta when they took over Minolta some years ago.
Limited lens range? A little wide of the mark. They lenses from 16mm - 300mm in native E mount made by them, plus an excellent premium Zeiss in manual and AF Batis. I don't think you can accuse Sony of having a limited lens range any more. On the A mount there are many top end Zeiss and Sony G lenses.
That aside, my advice to the OP would be to stick with Canon for his own uses, unless he has a bottomless budget - that way he and his OH can share equipment when they shoot together. The only problem comes when they aren't shooting together.
