Studio light kit for beginner
Discussion in 'Photography Beginners' Forum' started by El2, Feb 27, 2009.
  1. El2
    El2 TPF Noob!
    Oct 20, 2008
    264
    Sunny California
    I am looking into purchasing a studio light kit (after I sell my lens). I am looking at either the Alien Bee Beginner kit or Strobist. Any tip/advice on this?
  2. rlcphotos
    rlcphotos TPF Noob!
    Nov 23, 2007
    197
    Western Pa.
  3. Big Mike
    Dec 16, 2003
    33,876
    1,827
    Edmonton
    I'd also consider Elinchrom D-lites.
    As for whether to go with studio lights or a Strobist approach...you need to consider how you want to work. Either way can work but there are pros & cons. The biggest factor, to me, is portability and power. The Strobist method is very portable and you run on AA batteries so you can set up just about anywhere. Studio strobes need to be plugged in. You could use a large battery pack but typically you use them where you can plug into AC power.
  4. Samanax
    Samanax TPF Noob!
    Jan 1, 2009
    2,562
    Kaneohe, Oahu
    Is this for a home studio or for a on-location lighting setup?
    For a home studio I think studio strobes or constant lighting setup might be a better choice.
    For on-location shoots a strobist setup might be better unless you don't mind lugging around studio strobes/constant lights, battery packs and cables.
  5. adamwilliamking
    adamwilliamking TPF Noob!
    Feb 24, 2009
    481
    I second D-Lites. The D-Lite 2's would be the cheapest and you get 2 x 200 watt strobe, 2 decent sized softboxes, 2 stands, and sync chords, oh and they provide the first set of replacement bulbs. Next up from there is D-Lite 4, everything I just mentioned except the two strobes are 400 watts each.
    Keep in mind that depending on your camera you will have to buy wireless triggers, the best suited for Elinchrom is obviously the Elinchrom EL-Skyport, but industry standard is Pocket Wizard. I've heard that Pocket Wizards will last 10 years where as the EL-Skyports more like 2.
    Risregard the triggers If the 50D has ports the 40 prob. did
  6. El2
    El2 TPF Noob!
    Oct 20, 2008
    264
    Sunny California
    The strobist starving student sounds more of reasonable price for me. It will be indoors, but I would love to have a great portability if I need to set up in someone else's house.
    Thanks for the tips!
photography lighting kits for beginners
strobist beginner lighting kit
studio lighting kits for beginners
