Studio lighting
Discussion in 'Beyond the Basics' started by jlocoronado, Feb 22, 2009.
  1. jlocoronado
    jlocoronado TPF Noob!
    Feb 22, 2009
    Hi everone! My name is Jessica, I am an amateur photographer, and I am new to this site :) I am currently trying to figure out this whole studio lighting thing. For example, I am using a black muslin background, and 2 umbrella lights. How do I properly expose the picture so that the background is solid black and flaws cannot be seen? Any ideas where to go for studio lighting tutorials? Thanks in advance to anyone who might have some suggestions :sexywink:
    Jess
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Your studio lighting issues are not the problem... it is understanding a few of the basics. One great place to read, study and learn is the Strobist website.
    The basics of what you are trying to do is VERY simple:
    - get the lights CLOSE and strong on your subject
    - increase the distance between your subject and the background
    - use the fastest shutter speed possible... your camera's maximum sync speed
    That will black out the background.
    As for how to properly set the exposure... easy... set the camera to full manual and adjust settings (ISO, shutter speed and aperture) to taste. Using a histogram or a light meter, these are the proper tools to use to tell you if you are properly exposed or not... not the LCD on the back of the camera.
    Edit: Have you tried doing a search on this site, google or Youtube? There is a TREMENDOUS amount of info in all 3 areas. ;)
  3. jlocoronado
    Feb 22, 2009
    Thanks so much for the quick response. I actually have googled a lot on this subject and have found a few things that I have tried to apply when shooting, but I still didn't feel like I was getting the look I was going for. I will try your suggestions and appreciate your help!!!
    Jess
  4. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    Basically your trying NOT to light the background and also under exposing the background. This would be tricky with umbrellas as they send out quite a spread of light.
    [​IMG]
    This image I used a heavily snooted flash, I could have then fired it through an umbrella to soften the light, or used a softbox with a barn door etc.
    But what I was trying to do was stop the light spreading into the background of the picture. In my case the background is just the bedroom but could have been anything.
  5. Tinstafl
    Tinstafl TPF Noob!
    Dec 14, 2007
    95
    Valley of Virginia
    I do not know what system you are shooting but Nikon School has a great DVD on using their lighting system. It is done with speed lights for portable use. It does spend a bit of time showing how to control the various banks of lights but it does show how lights and lighting works.
  6. craig
    craig TPF Noob!
    Oct 30, 2003
    5,600
    21
    Hermosa Beach, CA U.S.A
    Basically you can not have light spilling all over the place. Flag your lights to keep the light from hitting the background. I have found that spot metering is useful in these situations. Check out this link from Stephen Eastwood. Stephen Eastwood|Beauty and Fashion Photographer | Tutorials
    Love & Bass
  7. Village Idiot
    Mar 20, 2008
    7,274
    406
    Wouldn't you have longer light fall off with the light closer to the subject due to the inverse square law? And a shorter fall off is desirable in these comditions.
  8. tsaraleksi
    tsaraleksi TPF Noob!
    Jun 12, 2007
    1,045
    Greencastle Indiana
    As long as the lights are not pointed at the background, having a brighter light on the subject will give you greater contrast between the background and the foreground.
  9. tsaraleksi
    Jun 12, 2007
    1,045
    Greencastle Indiana
    That's true assuming the lights are pointed straight at the background. However, getting the light closer to the subject and to the sides (so you can shoot down the middle!) lets you use less light for the same exposure and sends the light away from the background.
  10. JerryPH
    Oct 14, 2007
    6,111
    15
    Not really all that tricky once you know how. ;)
    [​IMG]
    This shot was taken with a 5-foot bounced umbrella on a 600W/s Profoto head on camera left with a hairlight on camera right behind the subject using another Profoto 600W/s with a 45 inch shoot-through umbrella. The backdrop is medium grey and subject is 6 feet away from it, yet appears pitch black.
    High shutter speeds and larger apertures are what helped the most for me in this case, but I did play with contrast a little to make the black background more even all around . I was at 1/200th and F/8 in this picture.
  11. JerryPH
    Oct 14, 2007
    6,111
    15
    Depends on conditions. Using a weaker speedlight you go close and hot, for fast light fall off. If using something stronger and further away, up the shutter speeds and increase distance from subject to background.
    The 5-foot umbrella I used in the post above this one was a good 6-8 feet away from subject, and becuase of it's angle a little more than double that to the grey backdrop behind.
  12. JerryPH
    Oct 14, 2007
    6,111
    15
    Exactly! It's all about placement and ratio. Darkened backgrounds require the light close becuase speedlights are weak, but when placed close and pumped up a little are going to give you a higher aperture to use, and a fast fall-off of light. Using monolights you angle more, fill from the other side and keep the lights off the background and using a higher shutter speed, the ambient (which is most of what will be in back) drops off fast, leaving you with dark or pure black backgrounds.
black backdrop placement of umbrella lighting
fall off studio light
