T2i Camera Setting Help
Discussion in 'Photography Beginners' Forum' started by AprilEye, Sep 14, 2010.
  1. AprilEye
    AprilEye TPF Noob!
    Sep 9, 2010
    350
    15
    Southern California
    I'm a new Canon Rebel T2i owner and I took this just on the AF setting. As you can see, where the sun hits the ocean, its over exposed. What would have been a better setting for this on this particular camera?
    [​IMG]
  2. AdrianC
    AdrianC TPF Noob!
    Aug 1, 2010
    155
    Edmonton
    If you're shooting straight at the sun, you're gonna get lens flare. (And odd exposures)
    Also, I checked out your exif data and you're using some very odd settings. F 22, 1/200 and ISO 400. I would read a book on basic camera settings, like Understanding Exposure by Brian Peterson. You will still get that overexposed portion in the picture tho.
  3. Negative ISO
    Negative ISO TPF Noob!
    Aug 25, 2010
    99
    Alaska
    Probably the only way to make that shot work is to shoot it twice. Meter once against the sky, which will deliver a very dark foreground. Meter again against the sand, and you end up with the shot you are showing us here. Add both shots to Photoshop and mix them up until you are happy with the results or you get tired of trying. :p
  4. AprilEye
    AprilEye TPF Noob!
    Sep 9, 2010
    350
    15
    Southern California
    This was taken with the automatic setting of the camera so they were created on their own (so to speak). I would like to check out that book you mentioned - I obviously need to get familiar with my DSLR. Thanks!
  5. sovietdoc
    sovietdoc TPF Noob!
    Jun 12, 2010
    1,134
    75
    rest of the world
    If you take this shot with AF, it will most likely fail because it will pick up overexposed glare off the water. On this shot, I'd recommend setting manual focus to the very lowest center point, choose "center weighted average" metering mode, and open the lens up to around f11 at least, or go f5.6, and raise the shutter speed up. Take a few shots and make sure the water/sky isnt too overly exposed, if the beach is a bit too dark, you can always lighten it up in photo editing tools, but you gotta make sure the sun/water is okay because you can't change that as much as the land.
    Another easier way would be setting up auto exposure bracketing to 5 shots (or 3) and combining 5 different exposures in one shot.
    This glare off the water is one of the main reasons people use circular polarizing filters. It takes care of that.
  6. Robin Usagani
    Robin Usagani Been spending a lot of time on here!
    Jun 6, 2010
    10,348
    2,175
    Denver, CO
    What does AF have anything to do with the over exposed image soviet?
    OP, first of all you need to turn off your AUTO ISO. Always keep it to 100 unless you have to raise it due to low light.
    You really need to learn about aperture, shutterspeed, ISO and camera metering modes. It is too hard to explain.
  7. sovietdoc
    sovietdoc TPF Noob!
    Jun 12, 2010
    1,134
    75
    rest of the world
    I prefer setting everything to manual, but if you use AF, depending on the metering modes you're in, it will over/under expose the image because it's not metering the right segments. Depending on what mode you're in, these cameras will take exposure measurements based on your focusing points.
best setting for a beach portrait with a eos rebel t2i
best setting for canon rebel t2i for the beach
best settings on canon t2 for shooting sunsets
camera settings for canon eos t2i
canon rebel t2i settings for beach portraits
canon t2i beach settings
canon t2i best setting for sunset
canon t2i exif data
canon t2i sunset settings
what settings i need to make a light sparkle on canon eos rebel t2iel
