Derrel
Mr. Rain Cloud
- Joined
- Jul 23, 2009
- Messages
- 48,225
- Reaction score
- 18,941
- Location
- USA
- Website
- www.pbase.com
- Can others edit my Photos
- Photos OK to edit
I've seen two good power chair camera mounts made out of tubing that was mounted to the frame of the chair, and then a curved portion came up and over to basically the chair driver's face/eye-level area. Camera was mounted on a ballhead. Wheelchair service and fabrication shops could easily handle this!
Another option would be a Bogen or Impact brand "super clamp", and the a so-called "magic arm" with a camera mount...this would be a nice way to shoot directly from a seated position. Ex wife's in a power chair, am familiar with issues with camera/lens combos for a C6-C7 person.
Manfrotto 035 Super Clamp without Stud - Chrome SKU#952606
Manfrotto 244 Variable Friction Magic Arm with Camera Bracket
The tripod likely will be able to support the camera. There's also the option of using a short,short monopod on the seat cushion, between your legs, and shooting that way. The VC or Vibration Control should be able to stabilize the camera/lens combo with the tripod head _loose_. In fact. the manufacturer might even suggest that VC be set to OFF if the tripod is locked down tightly~! However--MANY people have found that VR or IS or VC can be used with a monopod, or hand-held, or on a loosey-goosey tripod head.
Vibration Control can EASILY stabilize a loosey-goosey camera! All you need is something to hold the camera and lens more or less where it is handy to aim and shoot with!
I would use what you have, and learn to handle it, and then as time goes on, see if there might be a better solution or two you can arrive at.
