Time to get a DSLR
Discussion in 'Photography Beginners' Forum' started by pasteofanchovie, Sep 15, 2008.
  1. pasteofanchovie
    pasteofanchovie TPF Noob!
    Jul 21, 2008
    28
    St. Louis Area, MO
    My Canon Powershot G9 doesn't cut it for taking concert pictures and I want something more "immediate" than pictures from my Minolta SLR (I'm a little impatient :D). I'm looking for one that has low noise at a high ISO, spot metering and very wide aperture lenses available. Anyone have any recommendations?
  2. Overread
    May 1, 2008
    24,011
    4,153
    UK - England
    Well the lens range for both canon and nikon is very wide and has a good covering of wide aperture lenses - course how much are you thinking of? One company recently released an f0.95 50mm - £6000+ of course ;)
    Seriously though I think if high ISO control is your aim then you want to be looking midranage at the lowest level with regard to bodies and wide aperture lenses (50mm f1.2) are around teh £1000 mark
    Give us an idea of your budget
  3. pasteofanchovie
    Jul 21, 2008
    28
    St. Louis Area, MO
    I'm think my budget is around $1000, maybe more if necessary. Also is auto focus or manual focus better for concerts?
  4. Overread
    May 1, 2008
    24,011
    4,153
    UK - England
    Well I can't comment much on what you can get for $1000 *I am in the wrong country* but I would say that in lower light conditions autofocus can end up hunting so manual focus is a good thing to get practice in!
  5. Tolyk
    Tolyk TPF Noob!
    Aug 10, 2006
    524
    Calgary, Alberta
    Well, with that budget, Canon XSI and 50 1.4 would pretty much fill it, and the XSI is by no means the best in low light performance. If anything I'd go for a Nikon D300, it's low-light is pretty good, but the body alone is more than your budget.
    You may want to consider Pentax, the K20d is pretty good in low light as well, just slower auto-focusing. However, the 50 1.4 is by far cheaper than Nikon/Canon. The only problems with the K20d as far as I know are the JPEG compression sucks (so shoot in RAW) and the white balance blows in man-made light (so, again shoot RAW). This setup would run you around 1200 dollars (Canadian, not sure in America. No clue where you live though)
  6. pasteofanchovie
    Jul 21, 2008
    28
    St. Louis Area, MO
    I have no problem shooting in RAW that's what I do on my G9. I'll check out the Pentax, I think the local camera store I go to is having some kind of Pentax try out event soon. @Tolyk: Did you mean the K200D? The body alone for the K20D is $1200USD, or is that just exchange rates?
  7. epp_b
    epp_b No longer a newbie, moving up!
    Aug 22, 2008
    2,135
    12
    True North Cold and Freezing
    For that money, maybe look at a D90 body-only and buy the 50mm f/1.8 AF-D, which is only a bit more than $100.
    The D90's superb high ISO performance coupled with a fast lens will get you lots of keepers.
    Definitely autofocus. The subjects (performers) are constantly moving around, which will make manual focus frustrating, especially with a fast lens.
  8. Tolyk
    Tolyk TPF Noob!
    Aug 10, 2006
    524
    Calgary, Alberta
    Wow, that store is over charging.. I've got the K20D for sale at the store I work at for 1048 canadian. The K200D is a CCD sensor and not as good in low light, the K20 is the one I'd recommend by Pentax.
    The D90 recommended also would be worth looking into. Though it may not be as readily available, I know my store is already back-ordered on 'em and they're not even released in Canada yet :p
  9. ANDS!
    ANDS! No longer a newbie, moving up!
    Nov 14, 2006
    2,178
    Downtown
    If you go Nikon, get a used D80, and use the remaining bucks to buy a good starter lens. I recommend the Sigma 24-60 f/2.8. You can get both from Cameta Camera on eBay.
    If you go Canon, get a used 30D. Those can be had for about the same cost as the D80. Check out Photography-on-the.net and their "For Sale" forum. Usually you'll be able to find some good deals. The lens choice is the same.
    Do NOT go for a "niche" brand. Yes folks will swear by them, but when it comes time to get some new glass, and you wan't to go the "used" route (as you should) - you will face the limitations of such a niche choice.
  10. potownrob
    potownrob TPF Noob!
    Jul 8, 2008
    312
    Poughkeepsie, NY
    I like the way my D40 and Tamron 17-50 f/2.8 work in low light but if I were shooting concerts a lot, especially from more than a few feet away, I'd try to find an f/2.8 lens with image stabilization (IS, VR, VC etc.) and lenses that autofocus on the D40 are limited, so I'd be wishing I got another camera. Either that or use a tripod. Echoing ANDS!' recommendation, I'd try to get something like the D80 if possible and then find a cheaper fast lens (be it fixed or zoom). Something like the Tamron 28-75 might be better for concerts than a 17-50, especially if you're not up close. Fixed lenses will let in more light though.
