Triggering a 580EXII with a 600EX-RT
Discussion in 'Lighting and Hardware' started by photostudent1, Aug 29, 2012.
  1. photostudent1
    photostudent1 TPF Noob!
    Aug 29, 2012
    Is it possible to trigger a Canon 580EXII with a 600EX-RT? If there was a way that I could put just one PocketWizard receiver on a 600 and trigger the 580 instead of buying another PocketWizard receiver to put on the 580 that would be awesome.
  2. rexbobcat
    rexbobcat Been spending a lot of time on here!
    Nov 28, 2011
    4,946
    1,903
    United States
    Put the 580 in optical slave mode. It'll flash when it senses the flash from the 600RT
  3. photostudent1
    Aug 29, 2012
    I'm trying to figure out the cheapest way to be able to trigger two flashes from my camera. I already have a 580. Would buying a 600RT and a PocketWizard transmitter and receiver be cheaper than getting a less expensive flash and two PocketWizard receivers?
  4. rexbobcat
    Nov 28, 2011
    4,946
    1,903
    United States
    You can do it without either...unless the 600EX is setup way differently than the 580EX.
    But if you want to, go ahead and buy another receiver. It's more reliable than the optical slave.
  5. table1349
    table1349 Been spending a lot of time on here!
    Sep 9, 2006
    Pray tell, how does one do this with the 580?? :D
  6. rexbobcat
    Nov 28, 2011
    4,946
    1,903
    United States
    Hold down the zoom button, use the wheel to select slave mode to be on. It only works if you have another flash as the master though
    • Like Like x 1
  7. table1349
    Sep 9, 2006
    That's not OPTICAL slave mode. That is wireless slave mode. :D
  8. rexbobcat
    Nov 28, 2011
    4,946
    1,903
    United States
    It doesn't work without sensing input from another flash. It has to "see" the flash from the camera if the camera has a master mode like my 60D.
    I don't exactly know if that's a true optical slave, but it does not work without another flash triggering it.
    Wireless implies that it works like a radio trigger.
    I find what they call it to be very misleading, because I've known people who are like "oh cool, it's wireless! "...Why is it not working..."
  9. Tony S
    Tony S Been spending a lot of time on here!
    May 23, 2011
    2,094
    598
    Eatonville, Washington
    Optical flash is commonly though of aswhen the flash senses a light from another source, it can be triggered from any flash.
    Canon does confuse things though with the way it describes it's system as "optical based wireless ETTL".
    The Canon 580EXII uses infrared flash, still needs to be line of site and has bad issues in bright sunlight.
    Now here's the good part, the new 600EX-RT is backward compatible with older Canon flash units. It has both systems built into it.
    Canon DLC: Article: Speedlite 600EX-RT: Radio wireless basics
  10. table1349
    Sep 9, 2006
    Yep, it is an infrared system that can also be triggered with the ST-E2 in place of a flash unit on/connected to the camera body. Most canon units do not play well with true optical triggers, unlike Nikon units.
  11. HughGuessWho
    HughGuessWho TPF Supporters Supporting Member
    Jan 20, 2012
    1,642
    333
    South East Tennessee, USA
    If you are looking for "the cheapest way to be able to trigger two flashes" take a look at Yongnuo RF-603 Wireless Flash Trigger/Wireless Shutter Release Transceiver Kits
    They are certainly NOT professional grade triggers but work quite well are easy to use and are very reliable.
  12. table1349
    Sep 9, 2006
    Cheapest is a relative term, depending on the need. If the OP only has one flash currently then a Canon compatible flash may be cheaper than a flash and wireless triggers. Cheapest also is relative to planned future need. More info from the OP could be helpful here.
600ex 580ex trigger
600ex-rt med 580
can 600ex trigger 580ex
can the canon 580 ex ii be set up as a slave to the 600 ex-rt
connect 580 ex and 600 ex
is it possible to set the canon 580 exii speedlite as a slave to the 600 ex-rt
link canon 600-ex rt and 580ex ii
linking 600 and 580 canon slave
using a 600ex-rt with 580ex 2
will canon 580ex ii trigger the rt600
