TV-254C Carbon Fiber Camera Tripod + Ballhead Kit
Discussion in 'Linkdelight Photography Accessories' started by Link Delight Online Shop, Aug 8, 2010.
  1. Link Delight Online Shop
    Link Delight Online Shop Official Vendor Supporting Vendor
    Nov 4, 2009
    1,850
    7
    [​IMG]
    Features:
    • 180° folded design system: with the newly designed structure, the tripod leg can be folded invertedly by 180°, make it 25% shorter than ordinary tripod.
    • Leg Section Locking System : this will save more time and without the struggle of loose or rotating leg sections while locking or unlocking the leg section.
    • The knock-down centre column:
      1)centre column and locking system institutions to height adjustment more convenient, which can ensure stability
      2)by exchanging the centre elevation column to the short center column (optional accessory), you can obtain a very low height
      3)centre column can be using upside down, inverted to shootor or photography work, 3 non-slip foam sleeves for comfortable using.
    • Plucking Angle Adjuster: Simply adjust to the your wanted angle high, middle, low, allowing free adjustment according to actual needs
    • Matching Ball head: Matching with professional BH-18 ball head. Adopt to drag adjustment and clamp plate system, easy operation.
      1)Smoothly operate Quick Clamp.
      2)360° Panning
      3)-90°/+45° slope angle of the ball
    • Closed Foam Grip: it will give you firm and comfortable feeling, especially in cold days, this cold resistant grip act as an insulator between the cold tripod leg and your hand.
    • Spring hook: spring hook is to hang belonging like camera bags or heavy thing to increase stability during windy days..
    • 1/4” or 3/8” screw with centre.
    • Tripod bags: Bags are made of top quality materials, providing good protecting to your tripod and head.
    The price : $159.99
    more details :
    [​IMG]
    TE-06 Aluminum Alloy 3-Sections Camera Tripod
    US$104.99
    [​IMG]
    TK-254 Aluminium Camera Tripod + Ballhead Kit
    US$95.99
    [​IMG]
    Fotopro C4i Tripod w/ Ball head Photography Set Gold
    US$107.99
    [​IMG]
    Fotopro C4i Tripod w/ Ball head Photography Set Pink
    US$107.99
    [​IMG]
    Fotopro RM-100 Mini Flexible Griping Tripod M
    US$11.99
