Using Gels to Create Background Colors
Discussion in 'Photography Beginners' Forum' started by chrisburke, Jan 19, 2009.
  1. chrisburke
    chrisburke TPF Noob!
    May 25, 2007
    2,107
    Madoc, Ontario Canada
    Ok, so now that I have my cactus V2, its time to start trying some neat things... I have 2 flashes (both on v2 receivers) i have a white backdrop.. and if I'm correct in my thinking, I can us one flash behind the subject, put a colored gel on it, and it will put the color onto the back drop...
    so, in order to get the subject lit properly, i would put my other flash out in the front (i put it camera left for my test) i had them both dialed down to around -3 i believe it was, but it just seemed as though the rear flash (with the gel) seemed to take all the power... instead of just a red backdrop, the whole thing was red, me (as the subject) as well...
    how do i set up my lighting so that I can color my backdrop and properly light my subject???
    i have umbrellas (black and a white) and I have a home made softbox as well... for my tests they were just bare, no diffusion of any type...
    sorry i cant post the samples i took... i deleted them
  2. Katier
    Katier TPF Noob!
    Jan 14, 2009
    452
    Strobist is very good for this type of advice. But what I can say is that power depends on all sorts of factors. The best thing to do is experiment. Also you can try snoots to control where the light falls.
  3. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Make sure that the red is not messing with your auto WB. This might be a good time to use a preset or custom WB.
    As mentioned, just experiment until you find what power you need to use.
  4. chrisburke
    May 25, 2007
    2,107
    thanks mike. I dont use auto WB.. but if i think about it.. i dont think i changed it last night... and i think the suggestion katier made of using a snoot with help too.. as i was just using a colored cup instead of a gel, and the cup would likely spread the color out more than I want it to.
  5. Big Mike
    Dec 16, 2003
    33,873
    1,824
    Edmonton
    Bingo!
