Mike_E
- Joined
- Jan 26, 2007
- Messages
- 5,327
- Reaction score
- 266
- Can others edit my Photos
- Photos OK to edit
I don't know if this is the right place for this as I plan to use this camera quite a bit but I'm waiting by the box (or I would be if it weren't a holiday) for an RB ProS with a 90mm and a 180mm and a non-metering chimney.
OK, I had to tell somebody, the wife just doesn't get it!! LOL
If anybody that shoots an RB/RZ happens across this thread I am planning on getting a wide angle for it right away and am torn between the 65mm and the 50mm and would appreciate your input.
The 50 is the equivalent of a 25mm in 35mm format but I was hoping for wide wide. How does this lens work out in the 6x7 format? I wouldn't worry about it except that I've heard that it has a little distortion where the 65mm doesn't particularly and at an eq of 32mm for the 65mm if all I'm going to get is a general wide for landscapes I can live without the distortion.
Also,
1: I've heard that the S/SD 220 backs work fine for 120 (so long as you pay attention to how many shots you've taken) and was wondering if you have had any experience with this?
2: Is there much difference in the feel between the magnifying chimney and the regular waist level finder? I will probably get a WL anyway unless it's not worthwhile.
Thanks for the patience, I'm gonna go check the box anyway! ;^)
Also,
