Well! Poop!
Discussion in 'Nikon Lenses' started by KmH, Apr 7, 2017.
  1. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    I shot some time lapse this morning and the entire 200 frame series came out seriously over exposed.
    It took me about 5 minutes to discover what the problem was.
    The aperture mechanism in my Nikon AF 24-85 mm f/2.8-4D is binding and can't reliably stop down from wide open (to AF) to the smaller than wide open aperture I wanted to use.
    For those that don't know:
    The lens aperture is moved by a motor in the camera body (all Nikon DSLR bodies).
    When a lens is not mounted on a Nikon DSLR the lens aperture is closed to as small as it can get by a spring.
    When the lens is mounted on the body, the in-the-camera to lens aperture linkage opens the aperture as wide as it can go. That's so what we see in the viewfinder through the lens is a bright as possible and so the AF system doesn't have to wait to do it's thing when the shutter is 1/2 pressed.
    I figure the repair will cost me about $250, which would be about $100 less than less than replacing the (bought it used) lens.
  2. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,291
    3,231
    SE Michigan
    bummer
    didn't you send that in a while back to get it cleaned and focus sharper too ?
  3. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    Yep.
    I had it serviced (just clean, adjust, calibrate) by Nikon a while back.
    Like 2 years ago.
  4. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    I got around to scheduling a repair for the lens.
    Nikon's estimate, based on my checking Exposure Problem and description of the binding aperture, is $162 plus $16 to ship it back to me.
    I'll be shipping the lens UPS Friday morning, which is when I will next be going to the town where the closest UPS Store is.
    I'm west of the Mississippi, so it's going to Nikon Service on Wilshire Blvd in LA.
    • Like Like x 1
  5. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    The lens is on the way back. It arrived at the Lenexa, KS UPS facility at 3 AM this morning.
    Per the estimate the cost - B2 service rank - was $161.70 and $15.50 for return shipping (UPS Ground).
    • Like Like x 3
  6. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    UPS delivered the lens a few minutes ago.
    According to the Repair Invoice here is what they did:
    General check and clean.
    • Replaced the aperture lever.
    • Replaced the lens mount.
    • Replaced a retaining ring.
    Checked:
    Infinity Focus
    Aperture operation
    Exposure
    Communication
    Auto focus operation
    I figure the retaining ring failed letting whatever it was intended to retain get loose which damaged (bent?) the aperture lever and the lens mount.
    I suspect the lens mount damage was on the back side of the mount that can't be seen unless the lens mount is removed from the lens.
    • Like Like x 1
  7. astroNikon
    Aug 15, 2013
    13,291
    3,231
    SE Michigan
    how does it shoot though ?
  8. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    Like it did before it got fu'd.
  9. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,021
    494
    Do they guarantee repairs? Maybe a call to NY will let you send it to the east coast for a look see (of course on their dime). Not betting on it. Would at least demand refund.
  10. KmH
    Apr 9, 2009
    40,546
    5,542
    Iowa
    No! I mean they fixed it.
    It was a good as it was when I got it back 2 years ago after they cleaned it and calibrated the focus.
    That is my most used lens.
    I haven't mounted my AF 80-200 mm f/2.8D for such a long time I'm probably going to offer it for sale in a couple of days.
  11. benhasajeep
    May 4, 2006
    4,021
    494
    Ah that's good. I can't bring myself to sell the 80-200 f/2.8d. Wife uses it now mostly. But it's a great spare lens if they fancy electric lenses ever fail.
  12. astroNikon
    Aug 15, 2013
    13,291
    3,231
    SE Michigan
    My 80-200 and 24-85/2.8-4.0 are my 2 most widely used lenses.
    Then my 150-600 and 18-35
    I've sold most my other misc lenses that I rarely used.
