wet cleaning the cmos, which is best ?
Discussion in 'Digital Discussion & Q&A' started by canon_kid, Sep 11, 2010.
  1. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    what do you favor when it comes to cmos/ccd cleaning ? whats your fav solution and swabs ?
    I am looking for something cheap but effective if their is such a thing. has any one ever used a q-tip ?
  2. Neil S.
    Neil S. TPF Noob!
    Jul 16, 2010
    1,128
    21
    Japan
    I seriously hope you are not considering using a q-tip! Dont do that!
    The sensor is a precision surface, and great care needs to be taken before cleaning it.
    Read articles about it, and be careful.
    I have only done it once, on my 30D years ago, and it made me nervous.
    You need to buy something along the lines of this.
    Photographic Solutions Sensor Swab Type 2 (12-Pack)
    B&H link:
    Photographic Solutions Sensor Swab Type 2 (12-Pack) SS2BOX - B&H
    These are not cheap, but do you really want to scratch or damage your sensor? I think not.
    Hope this helps
    Edit: If you do get these make sure you get the right size, because there are different ones for different sensor sizes.
  3. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    no i wasnt going to use a q-tip i was just asking about it
  4. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    what about cleaning your mirror ? how would you do that with a wipe
  5. Neil S.
    Neil S. TPF Noob!
    Jul 16, 2010
    1,128
    21
    Japan
    I would probably use a pec pad and maybe some cleaning solution.
    Its just a mirror, so you dont have to be that careful.
    Also even if the mirror wasnt there, the camera would still shoot. All it does is allow you to see through the viewfinder.
    Its the sensor that needs to be protected.
  6. Garbz
    Oct 26, 2003
    9,713
    203
    Brisbane, Australia
    Wrong. If you foul up the mirror your camera loses the ability to autofocus. This is why the mirror is semi transparent. Only some of the light is delivered to the viewfinder, the rest goes to the AF system. This is also why there's sometimes a mirror behind the mirror. This is also why I don't recommend touching the mirror in the slightest. If you bend something it's a trip to the repair house. :)
    As for cleaning I used a q-tip once. Worked well. Wouldn't do if I had a choice. I didn't at the time. I was overseas in the middle of nowhere. It left a smudge and I had to reclean when I got home. Pretty much most of the sensor cleaning solutions out there are suitable.
  7. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    i have 2 or 3 specks of sticky dust on my mirror ( can see it threw the viewfinder with no lens on) would a q-tip work here and maybe a dab of alcohol or use a cmos swab and cmos cleaner ? tried blowing air but nothing
  8. Neil S.
    Neil S. TPF Noob!
    Jul 16, 2010
    1,128
    21
    Japan
    I didnt know this about the mirror.
    TY.
  9. pbelarge
    pbelarge TPF Noob!
    Feb 11, 2010
    2,680
    New York
    Do not use alcohol.
    Either B&H or Amazon has relatively inexpensive cleaing kits for sale.
    Here are a couple of links for more info:
    DUST-AID : DSLR Camera Sensor Cleaning Products
    Cleaning Digital Cameras - Photographic Solutions, Inc.
    Introduction - Cleaning Digital Cameras - D-SLR Sensor Cleaning.
    Heed what you read
  10. Flash Harry
    Flash Harry No longer a newbie, moving up!
    Jun 26, 2006
    1,966
    14
    Durham, UK
    Kid
    you've already been told, leave the mirror alone and if you clean the sensor use the correct procedure, correct swabs and eclipse or similar cleaning solution, or, you can end up with a busted camera/mirror/sensor and have a hefty bill for repair. H
  11. UUilliam
    UUilliam TPF Noob!
    May 28, 2009
    1,717
    Glasgow
    DO NOT USE A Q-TIP
    I did, It left loads of strands on the sensor, I then put LENS cleaning solution on it, it went all streaky!
    so i had to try use a q-tip with water to get rid of the streaks, i **** myself!
    eventually, I left the camera open for it to evaporate, that sorted most of it and just used a blower to blow the strands out the way until i could get it cleaned properly.
  12. canon_kid
    canon_kid TPF Noob!
    Sep 10, 2010
    32
    is their any way to clean the mirror ?
alcohol clean cmos
alcohol to clean cmos sensor
best ccd cmos cleaner
best cmos cleaner
clean cmos
cleaning cmos
cmos cleaning
cmos sensor cleaning
cmos wet cleaning
diy alcohol swabs cmos cleaning
