What causes those "bulls eyes" on "bokeh"?
Abby Rose
Michigan!
On those little out of focus circles, what causes the bulls eye appearance that you get sometimes? How can you avoid it?
Can you explain what you mean by 'bulls eyes'? Or better yet, give an example.
I think you are referring to lights in the background..... try putting some christmas lights up as a background and see what it does just as an extreme example.
The ones that you usually see, come from specular highlights (small bright areas). The shape of them reflect the shape of the aperture in your lens. Higher quality lenses often have more aperture blades, thus a rounder aperture opening, and some say...a more pleasing bokeh.
You can also shape the 'bulls eyes' by cutting out a shape in a card/paper and holding it in front of the lens.
from HERE
from HERE
I never knew that. So you just cut out a large shape and then make sure your subject is inside and then crop the edges?
Do you mean crappy bokeh like this?
I've been told that this is caused by VR working.
I was under the impression that took using a shaped aperture in a lensbaby or something. But Mike knows a lot more than me.
THIS kind of bokeh... I'm sure I have a worse example somewhere, but I cant seem to find it and its noticeable enough here. See how the circles on the middle right are like a circle within a circle?
I'd guess that it's a property of that particular camera (more specifically, the lens).
Mmm, I don't like it. Sometimes I just get normal circles, and sometimes I get those, and sometimes a combination, but for the life of me I can't figure out how to avoid it! It seems to do it randomly....
