What is the range in stops for a digital?
zedin
TPF Supporters
Irvine, Orange County, CA
So I am getting used to my new d70s and I was wondering. What is the range in stop from pure black to pure white for the sensor? Used to comming from slide film so tend to think in a 6-ish stop range. But anyone know if digital is larger or smaller in its range?
Each camera/sensor/software is different...but from what I've read, a typical DSLR should have a latitude that is wider than slide film but not as wide as negative print film.
Intuitively I'm setting for 5-6 stops... pretty much zone system
+2 gives you white, -2 gives you dark gray, but you actually need SOME info to print it with... so I never underexpose blacks by more than 3 stops because you just get too much noise
Mileage may vary. I'm using 300D
