What lens would you get?
Baaaark
North or South Pole... it depends
If you were buying a Rebel XS, and (of course) getting the kit lens, what would your second lens be?
I already have from some older Canons a 28-70 and a 100-300. But, I don't know if I should buy the 55-250 IS, or a 50 1.8. I'm REALLY thinking I should get the 50 1.8 first.
If you are taking more pictures inside, the 50mm 1.8 is the way to go for sure. If you like taking pictures outside more, consider the telephoto. Since you already have a 100-300 and nothing for low light, it seems like you would appreciate the 50mm more now.
As Philly said, it depends on what you are shooting mostly. The 100-300 has a similar aperture size as the 55-250. All you are gaining with the 55-250 is IS, and that is at a loss of 50mm on the long end. I'd go with the 50mm.
I think the 50mm is a must have in pretty much all camera bags...whether it be the 1.8 or the 1.4. The 55-250 is a good lens, but upgrading to a 70-200 2.8 or 4.0 is something that you will want to do in the future if you end up shooting more with the telephoto.
