When shooting indoors why do my pictures come out so white?
Discussion in 'Photography Beginners' Forum' started by crowl31, Dec 21, 2007.
  1. crowl31
    crowl31 TPF Noob!
    Oct 26, 2007
    93
    I'm using my XTI and for some reason if i try to shoot close to things the pictures come out like i'm holding a strobe light on them becuase the flash is so bright?
    Is there a way i can adjust that?
  2. JerryPH
    Oct 14, 2007
    6,111
    15
    Montreal, QC, Canada
    Use an off camera flash.
  3. Trish1977
    Trish1977 TPF Noob!
    Nov 26, 2007
    64
    Houston, TX
  4. JmPhotos
    JmPhotos TPF Noob!
    Oct 7, 2007
    42
    Hit Menu
    Arrow to the right one time to munu 2
    Arrow down 2 times to Flash exp comp
    Hit Set (round button in middle of arrows)
    Arrow to the left to make flash output weaker
    Arrow to the right to make it stronger
    Hit Set again to lock in your selection
    Or, instead of using a flash, try bumping your ISO up in dark situations
  5. crowl31
    crowl31 TPF Noob!
    Oct 26, 2007
    93
    Thanks for the advice, I picked up a soften screen today and I also started messing around with the flash settings like you suggested.
    :thumbup:
  6. Tumeg
    Tumeg TPF Noob!
    Dec 17, 2007
    9
    I made myself one, it works pretty well...
    Get a clear\transparent film canaster.
    Cut out a whole big enough to fit it onto the flash (I used a box cutter) and then slip it on, and start firing!
    It doesn't look very attractive, but if you were worried about looks you would buy an off camera flash
  7. BuZzZeRkEr
    BuZzZeRkEr TPF Noob!
    Nov 26, 2007
    436
    Va
    Well...you might not actually need to use the flash. Sometimes the flash pops up because your camera presets thinks it needs it for some low light conditions....but what actually ends up happening is that the photo gets completely blown out by the flash. I find (in some cases) light provided is much better for shooting things close up if your subject is not moving and you have a tri pod, or maybe just adding a soft light lamp through a cloth if you don't have an umbrella is all you need...just adjust your WB, and aperture and the camera should do the rest!
all my pictures in my phone gallery are white
why are my photos so white
why are my photos white
why are my pictures so bright
why are my pictures white
why are pics coming out so white with photography strobes
why do my pictures come out white
why does my pucture come out white with flash on
why is flash so bright in iphone pics
why my pictures are white
