which compact flash card
miskin83
Hull
Hi
I am purchasing a canon 350d on Wednesday.
Jessops have a standard compact flash card on sale (1gb £65.00) or a x100 speed (1gb £110).
which one should i Get??
Also are filters essential(uv protection???)
Ta
Anthony
With a camera like that...the speed of the card won't matter much at all. I suggest the cheaper one.
UV filters are mostly used for protection of the lens. If it gets dropped or whacked, it's cheaper to replace the filter than the whole lens.
A polarizer is one of the only filters that you can't replicate with image software (Photoshop etc)...If you have one filter...make it a polarizer.
just a note on the polarized filter if you get a tinted one your pictures will be darker it is like sunglases for your camera
i use clear skylights to keep my lenses form geting scrached
I wouldn't refer to polarizing filters as 'tinted'....they will however block about one stop of light (which will be compensated for by the camera)...so I wouldn't recommend using one in low light situations and definitely not indoors.
The can make a big difference when used outside, under sunny conditions.
